Patio's 2000 4Runner Buildup
Patio Burrito
Greetings all, I decided to finally do a build thread on the Runner. This forum has been very inspirational and is chock full of great and innovative ideas.
Purchased in late 2010 with around 150K on the odometer in San Diego from a family who had their third child on the way and needed more room. Completely bone stock except for an aftermarket stereo because the stock one crapped out. That would not last long!
attachment.php
General Vehicle Info:
2000 Toyota 4Runner Limited 4x4
3.4L V6
Auto Trans
E-locker
Desert Dune Metallic (by far my favorite paint color, really hides dirt well)
attachment.php
Here is the list of what I have done so far:
Front Suspension:
Total Chaos Uniball Upper Control Arms
King 2.5" Coilover Shocks
Total Chaos Secondary Shock Hoop
King 2.5" External Bypass Secondary Shocks
Total Chaos Weld-on Spindle Gussets
Superpro Polyurethane LCA Bushings
Total Chaos Poly Rack Bushings
Modified Tundra Inner CV Joints on 4runner-length, Tundra-splined 4340 axleshafts with hi-angle inner boots
attachment.php
Rear Suspension:
Total Chaos Adjustable Rear Link Kit
King 2.5" Remote Reservoir Shocks with Compression Adjuster Knobs
Toytec Superflex Rear Coils
King 2.0" Airbumps in Custom Mounts
Swaybar endlinks from the front, about an inch longer than the stock rear ones.
attachment.php
Rims/Tires/Brakes:
255/85R16 BFG KM2 Tires
TRD FJ Wheels w/ OMF Beadlocks
Spidertrax 1.25" Hubcentric Wheelspacers Front/Rear
Tundra 231mm Front Brake Upgrade
attachment.php
Exterior Mods:
Total Chaos Front Bumperette/Lightbar/Skidplate
Baja Designs Onyx Lightbar
Baja Designs Squadron Amber LED's
TJM Awning
TJM Bouilia RTT
Fabbed Roofrack Bars to mount Awning and RTT to
Stubbs Sliders
attachment.php
Interior Mods:
Pioneer Double DIN DVD Player
Icom V-8000
Garmin GPS
ARB Fridge
Rear 2-Drawer Storage System/Sleeping Platform
Weathertech Floor Liners
LED Interior Lighting
Diehard Platinum Battery
attachment.php
Future Mods:
Toytec Superflex Rear Coils (done, 7/14/14)
Dual Diehard Platinum Battery Setup
Pelfreybilt Rear Bumper/Spare Tire Swingout
Wow! Very Nice, like the storage idea too. Well thought out and executed. You need no luck! :banana:
WOW! You are the king of kings! I've just got coil overs up front.. Are you running he Tacoma replacements or the tundras?
Wow you have an amazing suspension setup on your 4runner. That is the exact setup I want to have on mine in future when I can afford it lol.
Not sure how much wheeling & flexing you do but I've read of some who are lifted having issues with the rear sway bar contacting the elocker during flex even with the front end links installed. See any evidence pointing either way with your setup?
I don't think I've ever seen someone run bypasses with mid travel. That thing is set up nicely. I'd also like to know more about the mini bumper and see some more pics of it along with mounting points. I take it that the skid plate is tied into the front crossmember? What are your travel numbers front & back? Do you run limit straps?
Wow man good job. Very sneaky with 2k+ in king shocks under it hahaha. What are the specs in the rear kings?
Here are some close up pics of the rear Kings, they will soon have a part# and be available from King. Talk to Brian Groves there, super knowledgeable and easy to deal with plus they are willing to do custom stuff that most other shock companies don't want to deal with. One of the (many) cool things about them was the attention to detail that went into the upper mounting. Most companies just have a stud with a couple of bushings, a washer, and a nut. These have all of that, plus a plastic coated innersleeve that fits nicely into the mounting hole on the chassis and a machined billet aluminum dished-plate that goes between the washer and the bushing.
Ran Gold Mtn Trail up in Big Bear this weekend and kept an eye out for that issue. It never even came close (swaybar to E-locker servo) even when flexed out.
Had to go early on Sunday AM, every other time there were 30+ Jeeps tamponing the trails.
Front bumperette/skidplate is mostly 1.75" 4130 and has saved my bacon during an unfriendly encounter with a big Yucca Tree. It has a 3/16" AL skid that goes all the way to the back of the lower arm mount. Mounted to the bar are two Baja Designs Squadrons with amber lenses for cutting through the dust and a Baja Designs Onyx 20" LED bar. I will never drive faster than these things can throw light!
