modifing stock bumper
Pate
hi guys, i've seen a lot of pickups from early 90s and a few 3rd gen from 96-99 were they split the original bumper and use just the upper half of it, i think they look good, but on 99+ 4runners, it seems a bit more complicated. There is not only the fact that you don't have the turning signals on the upper part (the least important issue) but you have that kind of a guard going over it, and on top between the mask and the metal is a plastic lip, most 99+ owners should understand which parts i refer to haha.
Here are a few pics of half bumpers, and on one of them the guy did a tube defense underneath it, which in my opinion looks really good.
102376d1384374782-official-collection-solid-front-axle-3rd-generation-4runners-truck2.jpg
102389d1384375010-official-collection-solid-front-axle-3rd-generation-4runners-jeff11il.jpg
Have anyone done this on a 99+ bumper? or at least anyone knows if you could disasemble the bumper without using a grinder?
You can remove the lower 'valance' (plastic) portion by removing the series of ~8 bolts holding it to the metal part of the bumper. Then you can trim whatever you like
Max
thanks mate! and it's the top part supported to the frame or do i have to weld some supports? i know i should go looking at my truck but it's at my granny's since i don't have space at home haha
Here's mine before/with and after/without the lower portion. I don't have a preference either way with the stock bumper but mines off and I do like the tube design in place of it with the stock bumper. I think that looks good.
Dous' original build had no bottom part.
Didn't really pull the same look as the 96-98 bumpers
^^^My first time seeing it done with the 99-02 models^^^
I know it's not a 99-02 style, much easier with the 96-98's...
anyway here's mine- :hatsoff:
Project I'm messing around with:
photo4_zps6e1ee7ef.jpg~original
I also recently chopped up a 99+ and moved the turn signals up into the corner lights.
rdgt4r did some trimming to his bumper also
IMG_1172-1.jpg~original
dude that looks pretty good, i was thinking about using the top and making holes for the signals, but after seeing how it looks (ugly compared to 96-99) and how it looks trimmed, that's the way to go! thanks a lot guys for the pics
QUOTE]
That looks awesome with the custom tube bumper in place of the valance. Thinking of doing something similar. And those flares are definitely for a Taco. Ive wondered if Taco flares could actually be fitted on a 3rd, but have never actually seen it done until this. Anyone know whose truck this is?
QUOTE]
Not sure whose it is, but here are more pics and an old thread on it.
excuse the yt link lol Flex shots of 3rd Gen 4Runner SPRING OVER SAS - YotaTech Forums
How'd you mount your front plate? And do you have any type of body lift on that? I don't remember my bumper being able to see that much when I didn't have my valance on. I think I might take the valance back off o.o I like how yours looks...
Hey thanks-
I mounted my plate using zip-ties over some steel mesh aka= gutter guards from Home Depot, which is only like $3. Try it out if you don't like it, you could always put the valance back. Question though? Do you have Limited fender flares? Because I had to cut mine to make it look good and flow right...
I'm not using any body lift of any sort- Just a 3" suspension lift (1st page of my build)
*post up a pic here if you decide to do it :photo:
Hey thanks-
Ahhh cheap is always better. :p I might have to check that out because the only reason I replaced my valance was because I don't have a skid, so I have like 2" of my radiator exposed... May check this out, and eventually find a skid...
I do have the fender flares but I broke them both already so the little bumper pieces are already not on there. Had to replace the bumper and the bolts were rusted in so badly I couldnt properly remove them from the old bumper. Eh it isn't much to do but I'm gonna be extremely busy for a while so, not much happening to the rig. I've got all the parts to a turbo kit and next paycheck to hve the last piece welded up, and I won't have it in for probably 3 more weeks.. XD
