MTD's ForeRunner Build - Narrated by Jeremy Clarkson & James May
I got to drive my roommates supercharged Tacoma for the first time, not regeared and spinning 34s and man can it haul ass! I didn't realize that "little" of a power increase would feel so much, he's not even running fuel mods or anything extreme. Makes my heavy ass runner seem slower than it does already :cry:
Even with the air dam (RTT) on the roof and the hills along the mississippi I got 18.2 MGP! I am digging this whole 5 speed thing lol :reddance:
dLYHJD6afG03JL9aWttJDZbVPQ3OACCeBqO2LW7fUuQ=w1239-h929-no
Also some new goodies cam in the mail today. I blew a MEGA fuse the other day when I was installing my Aux battery, and I couldn't find a new fuse locally to save my life!!! So I hopped onto geuinedealz.com and picked me up a new one! (Genuine dealz by the way is completely genuine, really great guys to work with and they have the best prices on the web for wiring and electrical stuff)
And the Neat retro badge that I scored off of eBay!
Off to an awesome start, can't wait to see where this thing goes. I followed your first one, and now I'm going to follow the progress of this one! Good luck!
Thanks man! Not too much more will be happening mods wise this summer, just some small stuff. It's time to get out and use it now lol
Tomorrow I am going to head up to Jackson County Wi for some forest camping so I took a trip to the local walmart today to get some goodies before I left. I picked up a Coleman folding shove and hatchet, some propane, and a length of paracord. I forgot the beer though! :doh:
I also decide to take apart the MEGA fuse that I blew the other day to see what it was like inside and in true engineer/redneck fashion is said "i can fix that"! So I did! Keep in mind though I would never use this as a permanent fuse because I did add more solder to the mix which may change when it fails, but in a pinch for a spare it will do just fine! In theory it should work because it is the cross-sectional area of the copper pieces that determine when the fuse blows. It may blow at a higher amperage though because of the properties of the solder used and the amount applied. The reason I am reasonably confident that It will work though is because pretty much all solder has the same set eutectic point.
Before:
After:
:humble:
Yep but doesn't that basically defeat the concept of the fuse? You solder job may or may not act as the fuse was originally designed. :yield:
I figured you would chime in here lol, If you read the entire post I explain why It would work in a pinch. It still functions as a fuse it just may blow at a slightly higher amperage. Therefore I would never use it as a day to day thing, but seeing how my battery has a 6000 amp short circuit current even if it would blow at 400 amp now it would still help lol.
It is pretty nice, and up at elevation like you guys it's even better. For me though I like that it is closer power wise to what my 05 tacoma with the 4.0 used to be. I am not planning on running a smaller pulley or fuel mods anytime soon either unfortunately. That being said though it will happen :first: ........ eventually
Alright enough dicking around with technical stuff, I finally got out this weekend and hit up some trails. I went up to Jackson County with the intention of camping in the county forests. I got up there a little late yesterday so I ended up doing a little exploring and then staying in an ATV campground instead of at a forest site. This morning then I got up early and went to hit up every trail in a 20 mile radius and there are A LOT!!! I just scratched the surface but have a pretty good start with the GPS data that I did collect today. There were quite a few trails that I wanted to do too, but didn't feel comfortable flying solo on. Even though I have a winch there are those cases where I could still get stuck.
I would have stayed another night but the weather man said there was a major risk for sever storms tonight, and after what happened at Devils Lake I am a little paranoid... I didn't want to show up as a headline.... :/
Any way enough talk time for pics!
Just hit the first trail after an hour drive.
Found an awesome campsite on an old quarry lake
The quary was half redneck party hollar and half offroad park
https://lh6.googleusercontent.com/-...AAAAGkc/Dlv866JstLo/w900-h600-no/IMG_8603.jpg
ATV Hill Climb that I took some poser shots on. I tried the one on the other side of the hill. I made it up, but there was no where to go on top lol.
Next I discovered a sand pit to play in. Basically it was decayed sandstone and if you weren't careful you could find a piece that hadn't decayed and really mess something up.
I need some sliders lol that is only about an inch away from having a bad day lol.
Annnnd camp!
Being the good samiritine that I am I cleared the trail instead driving around lol.
Before:
After:
You see some interesting things out here....
Washout wonder if the trail is ok above?
Nope.
Soooo much sand!
And that's it. I really like how the truck handeled, there was not one time that I was worried that I would get stuck/hungup or otherwise screwed lol. It was my first time out wheeling solo and after this I am feeling pretty confident in both my and the 4runners capabilities
Sweet. Have fun. Can't say that I would take my 3rd gen there though. Let us know how that goes. Toyota event down this way in August. You should come down.
I wouldn't bring my 3rd Gen there if I were you either. I would much rather be going up north again for expo style stuff, but since I have flaked the last couple times on these guys I figured I should go lol. It should be fun though. And if I don't feel like trashing my truck I can always ride with one of the Heep guys lol.
When is the August event? I may be able to make it down that way depending on the weekend. August will be a busy month for us but I can see what I can do. We are actually planning a overland camping trip for up north one of the weekends which should be fun. My other thrid gen buddy and our GF's are gonna go roam around up there lol
On monday after I got back from camping I decided it was time to fix all of the ugly dents that my ladder put into my tent frame. I got these rubber no skid adhesive pads from my local harbor freight and cut them to the necessary size.
I was productive after work tonight. I got my Midland 1001LWX installed and the Blue Wire Mod done.
I didn't want to mount my CB in the same spot I had it in the last truck because if I got in an accident i would loose a knee cap, which would suck lol. I had seen a couple people mount them in the ash tray location before and I had good feeling that the 1001 would mount there too and since its the CB I wanted to upgrade too I was going to make it fit!!!
Pulled the dash apart
Out with the old and in with the new!!
IT FITS!!! Minor trimming required though.
Instead of using screws or someother kind of fastener I decided to forgo the headache and used a combination of press fit and VHB tape to hold the unit in place. It worked great, it isn't going anywhere and no rattles!!
I did the rear diff breather extension today. I followed the write up on JA's site top4runners.com It's a great site if you have never been on it you should probably check it out.
The old
The new
This weekend was really fun and really expensive lol. I went with a couple jeep guys from Madison to The Cliffs Insane Terrain offroad park in Marseilles Il. I was not sure what to expect when I got there becasue all that was in the parking lot were some beat jeeps (heeps), and a ton of quads. I was hoping to avoid the mud but that became apparent that would not happen as soon as I hit the first trail.
At some point on the trail, possibly when I hit the really deep hole where the water came into the cab, I managed to so thoroughly soak my alternator with muddy water that I killed it. My battery light came on coming off the last trail of the day and there were many cuss words exchanged. Keep in mind at this point I am 2 hours plus from home and in a different state... We made the call to drive it as far as the battery would take us after pouring water onto the alt to see if we could get it working. We made it all but 10 miles south of madison when my abs light came on and the radio cut out. Next thing I know im super low on power and my tach is going nuts... We pulled off at a gas station and went through my tool box to see what we could jerry rig up to use my aux battery which was still fully charged because my ACR isolated it when the front battery stopped charging. I was able to use a short piece of 2 GA wire to jump the terminals of the ACR. I thought I might blow a fuse trying to start it with the back battery, but she fired right up and we were back on the road! :guitar3: We went right to the local carwash and tried to blow out any mud still in the alt, but no dice it was dead...
I found a screaming deal though on an alternator reman from Advanced auto that is just down the road from my place. I bought it for $130 with no core and a lifetime warranty. What I am going to do is rebuild my Denso and then put it back on and keep the Advanced auto one as a spare. I ended up just swapping in the new alternator in the parking lot of advanced which was super simple actually lol. I think I had the old one out and the new one in, in less than a half hour.
Well then yesterday when I was washing the truck I was unknowingly funneling water into my rear diff by way of my extended diff breather. One thing I can tell you that if you do that mod, cut a new hole, don't use the one under the gas cap to run it through :/
Damage Report:
1x Alternator
1x Botched Diff Breather extension
1x rear diff flush for the latter
1x stretched parking brake cable
Pretty much this is what everything looked like in the whole park... I hate mud...
I did get to pull out this jeep though lol. He dropped into a SUPER DEEP rut there are some other pics of the other side that shows his fender under water completely.
Triumphant 4Runner :D
I took a different way around lol
And the GIF lol
Headed into the creek.
We found an RIT ramp and I had to do it!!! I was actually quite pleased.
This excursion was a little out of his element I think... It was a completely stock diesel with some A/T's on it. He also had what looked like his entire family in it with him lol, and they didn't look like they were having fun. The trails were almost too tight for the 4Runner I am not sure what he thought he was going to do.
Here is the hole I got stuck in where the water came into the cab and I think where my alternator said Fu@k you! The only pick we have since we couldnt exactly open the doors lol
I thought the bottom of the is hole was a little more solid then this lol, I stopped just before the rock, my spotter was then fired lol. Had to be winched backwards. This was still better than the other option which wasn't even big enough for the jeeps lol.
