08-08-2014, 08:47 PM
Real Name: Robert
Real Name: Robert
How To: Make Your Own Rear O2 Simulator for $5
Before I get into describing how to build your own rear O2 simulator, I just want to say that I did not come up with this mod on my own. You can search Google and find all kinds of write-ups describing this method. However, I didn't see any write-ups here on T4R, and since many of us suffer from the P0420 disease, I figured I'd share it here as well.
I also apologize for the lack of pictures. I didn't think about posting this write-up until everything was put together and installed on my rig. I encourage other people who do this mod to take pictures along the way and post them up.
You will need to have a working rear O2 sensor for this spoof to work. By "working" I mean that all you have to have is an O2 sensor that's putting out some kind of signal. You're O2 sensor can still be "bad" (putting out bogus signals), but as long as it's putting out something, we can modify it and fool the ECU into thinking that the rear O2 is okay, and that the catalytic converter is working like it should be (even if you don't have one). This method is far cheaper than replacing the rear O2, and is MUCH MUCH cheaper than replacing your catalytic converter.
DO NOT DO THIS MOD TO YOUR FRONT OXYGEN SENSOR. ONLY DO THIS TO THE REAR ONE.
Before you get started, you'll need to run to RadioShack and pick up two items:
A 1 Microfarad (1μF) Capacitor - RadioShack part number 272-1055
A 1 Mega ohm (1MΩ) Resistor - RadioShack part number 271-1134
This should cost around $5 or $6.
Step 1: This step isn't required, but it will make things easier. Unbolt the rear oxygen sensor from the exhaust pipe, which is held on by two 12mm nuts. Then disconnect the rear O2 sensor pigtail from the main wiring harness. With the rear O2 sensor completely removed, you can modify it on your work table or where ever you want, instead of cutting and splicing while underneath your rig.
Step 2: Cut the blue and white wires on the oxygen sensor. Leave the two black wires alone, they are part of the heater circuit and we don't want to mess with that. I chose to cut the blue and white wires halfway between the sensor element and the plug connector. Wire in the resistor and capacitor as shown below. I chose to use heat shrink butt connectors, however if you want to use another method such as soldering, crimping, etc. then that's completely up to you. Use whatever method you like. Just make sure it looks like this:
You'll notice that I have the first diagram labeled "incorrect" and the second one labeled "correct". I've seen some diagrams posted on the internet that show the first wiring diagram. Don't do that one. Your truck will read 0.0 volts at the rear O2 and will throw a code P0136 "O2 Sensor Circuit Malfunction". Go with the second diagram.
Step 3: Make sure the resistor and capacitor are protected from the elements somehow. I'd recommend wrapping everything up in electrical tape. Then re-install the O2 sensor back into the exhaust pipe, and hook the pigtail connector back into the wiring harness. Make sure that none of the wires hang too close to the exhaust pipe (you may have to zip tie things out of the way).
That's it. This should help get rid of your P0420 code for good, whether you have a catalytic converter in place or not. My '99 has had a P0420 code since the day I bought it, and it's been like that for over 2 years. It has the California style emissions and 2 catalytic converters, yet it still threw a code for "Catalyst System Efficiency Below Threshold". Every time I'd reset the Check Engine light, it would come back right away with the same code. After building and installing this O2 spoofer, I have yet to have the Check Engine light come back on.
1999 Toyota 4Runner Limited 4x4 - Turbocharged Garrett 57-trim T3/T4 - URD AFR Sensor Calibrator - DW255 fuel pump - 7MGE Supra 315cc “lime green” fuel injectors - 231mm Tundra Brakes - B&M 70264 Transmission Cooler - Monitoring ATF Temps and AFRs With My iPhone - DIY Projector Headlight Retrofit - Cooper Discoverer AT3 - OME 906 Coils & Rancho 9000XL Shocks (Rear) - Airlift 1000 - RadioShack $5 Rear O2 Simulator
2000 Yamaha XR1800 Jet Boat - MR1 4-Stroke Engine Swap
Reason: Re-inserted diagram that disappeared
08-09-2014, 06:52 AM
Real Name: Alex
Real Name: Alex
That's pretty cool! I spent the $100 on the URD o2 sim. Wonder what the difference is :-)
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
08-09-2014, 09:20 AM
$98, is my guess.
08-09-2014, 07:02 PM
Real Name: Julian
Real Name: Julian
Could you show some pictures of it under your 4runner I'm tired of looking at the damn check light for the same code... P0420 Bank1
08-10-2014, 03:29 AM
Real Name: Alex
Real Name: Alex
Originally Posted by Brique
$98, is my guess.
Haha, probably. URD has some big description of why only theirs works, but it's probably a load of crap =)
From the site:
Note: Be cautious of O2 sims that replace the rear O2 sensor with a falsely gererated signal.
Toyota started using a wideband type O2 sensor (air/fuel ratio) in the front position for better engine control. These wideband type sensors need to be recalibrated from time to time by the ECU. The ECU uses the rear sensors for this recalibration process. The ECU cannot properly recalibrate the wideband sensor using a falsely generated signal. This process is explained here, US Patent 5706654.
Use only a URD O2 Sensor Simulator on these vehicles to avoid poor performance, drivability issues and poor MPG.
08-10-2014, 04:08 AM
Real Name: Kevin
Real Name: Kevin
I thought it was only California emissions trucks that had a wideband in front?
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
08-10-2014, 06:54 AM
Real Name: Robert
Real Name: Robert
From the site:
I agree that a true simulator probably wouldn't work, for the reason stated above about calibrating the front wideband. You need to be able to intercept the signal and modify it, instead of a 100% falsely generated signal. I have a feeling that this write-up, and URD's product probably work off of the same principle, with maybe slightly different values for the resistor and capacitor. That and URD's product is packaged all nice and neat, with connectors for a truly plug-n-play device.
08-10-2014, 07:00 AM
Real Name: Robert
Real Name: Robert
Sort of. The '99 and 2000 Cali models had the 2 cats & wideband up front, Federal emissions had the typical narrowband up front and 1 cat. 2001 & 2002 models all came with 2 cats & wideband up front, which is still commonly referred to as "Cali emissions" even though both Federal and Cali were the same in those years.
08-10-2014, 09:42 AM
Real Name: Robert
Real Name: Robert
Sure.
Here's a half decent picture I took this morning.
Looking back, I should have cut out a section of the blue wire to account for the added length of the resistor.
08-28-2014, 11:43 AM
Did this to my '01 this weekend. Followed your write up and it worked. Turned off my CEL due to a P0420.
DesertRunners T4R
08-29-2014, 06:39 PM
Real Name: Robert
Real Name: Robert
Good deal, glad it worked for you.
11-15-2014, 07:57 PM
So I won't focus on the point that this mod is illegal (that's not say I don't think you should do it, I think it's stupid laws that make this illegal), though people should know that before they do it themselves, but I will just point out that the URD explanation is probably correct to some extent.
Just dropping a cap and resistor in there WILL change the output of the sensor and change the performance tuning based off the O2 sensor reading. I don't know what's in the URD sim, but it's probably more than just a cap and resistor. They very well could have put in some additional electronics to condition the signal in such a way that it passes, but still gives reasonably accurate feedback for performance tuning. I don't know what inside it or what it does, but if it were just a cap and resistor, someone would probably have figured that out by now.
Just food for thought before anyone feels ripped off by buying a URD sim.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
11-16-2014, 11:18 AM
How is this illegal if you live in an area that doesn't have emissions or if your car passes the sniffer test?
This is most definitely all the URD device does. The O2 sensor oscillates rapidly between 0.9v (rich) and 0.1v (lean). A failing sensor won't oscillate correctly between the required values. I'm guessing the resistor limits the peaks while the capacitor boosts the valleys of the sin wave so essentially "conditioning" the signal. Not a bad profit margin for them.
11-16-2014, 12:47 PM
Pardon my ignorance but does eliminating the cat really make a big difference?
What kind of difference would you notice by installing the simulator and removing the cat?
.::TRD; no, your jeep can't fallow this.
2000 Black 3.4 N/A 5 speed 4x4, most recent mod: OE e-locker setup with 4.30 gears from an auto. ARB front winch plate bumber in the garage.
She's, starting to be less stock, with about 226,428 miles as of 5/27/16.
