radio & AC location swap?
gotee4jc
has anyone ever moved their double din head unit from the bottom to the top and moved your AC controls to the bottom? if yes, can you show some pictures and explain how you did it and with what parts...thanks
I'd be curious to see how/if anyone has pulled this off. I would think it would be pretty difficult because the HVAC controls for temperature and the vents are mechanical cable-driven, not electric.
Yeah I'd love to have the radio up high like i was in my old FJ-60.
But the re-engineering of the HVAC controls would be horrendous...for me, anyway.
Its possible
guess i should have stated that mine is a 2001 Limited. i didn't mean i want to move the vents, i just want to move the radio up one slot and the ac controls down 2 slots. if anybody has some pictures or videos, please post em!
Wow!!! I want to move my vents. JamesDean: Did you make that bezel or buy it ? That looks awesome, I mean really awesome! I want one :)
It is not mine sadly, that guy is a member here i think or ttoa. Here are a couple more of his runner I believe he custom made it though.
Yep ... my 97 has "manual style" cables and I don't see it could be easily done in a functional way.
Based on the posts above I guess later years have no cables and it wouldn't be that hard.
Even though newer models got knobs that can be turned, there is still a cable to do the operation.
It's just wires plugged into the control unit on my '01. No cables in the back of the controls on mine. I've been in there many times working on my led swap.
Edit: that said, they're pretty much cut to length and so you'd have to do some work in there to get them to reach down i think.
1999 Limited is a wired plug and play also.
reviving
Searched for this and found this thread from a few years ago. Did anyone ever do this cause I really want to, I hate how low my radio deck is... I feel like this would be immensely beneficial
The depth is going to be a real problem. You can see how much that custom dash sticks out, and that's because there isn't as much depth in the upper half of the console as there is in the bottom.
This is going to be way more trouble than its worth for most people. You're going to have to fabricate a completely new trim panel for the center.
Reviving This Topic
Hi All. I'm interested in swapping the climate controls with the head unit on my '01 Limited, as it'd be great to not have my floating head unit screen covering up the climate control buttons. I've come up with a few creative ideas, but ultimately none make as much sense as simply swapping the top and the bottom of the bezel.
Has anyone else finally come up with a borderline OEM-looking pre-fab bezel that would support this idea?
If not, any stereo installers (or ex-installers) hanging around who want to produce a custom piece, for the right price?
Anyone know more of how this was done? I ran across this on a Yotanation product. Very similar to the one shown in this thread. Relocating the ducts but not the controls seems like the ideal way to do this.
You can get those vents off amazon and ebay, even found rectangular ones that at more OEM in appearance 2X Truck RV ATV Heat AC Air Exhaust Vent Dash Ventilation outlet Universal USA+ | eBay
I know some Pioneer "floating" heads allow you to remotely mount the main electronics, and a lot of newer headunits have shallow bodies because they don't have CD players.
What I'm wondering though is what all is behind the dash, how would a go about tapping off the ducts and routing them down to the new vents. How would I close off the original vents. What do I then need to get a head unit mounted up in the higher position. I've never really done any kind of fabrication before and I'm at least trying to get an idea of what all would be involved.
