SURF RUNNER
I already did some searches and did not find any details about removing the washer fluid tubing and connectors.
My sport hood is probably going to arrive at the downtown Bryan Greyhound Station towards the end of this week. The only time I will probably be able to pick it up and switch hoods is during my lunch break. There is an auto mechanic two blocks from the station that works on my 4Runner from time to time, so most likely I will have him help me during my one hour lunch break.
I know this should be incredibly easy, but it doesn't exactly look that way when I was under the hood earlier this afternoon. I know that I can probably just yank out the washer fluid line and connections, but I'm trying to do this without tearing anything up. My factory hood is in very good condition and I would like to keep it that way if possible for whoever buys it.
It doesn't look like the plastic tabs holding the heat shield are replacable. I read that they are plastic so that in the event of an engine fire the tabs will melt causing the heat shield to drop on top of the engine and possibly smothering the fire.
2nd Photo: How does the tube and the tab/clip come off here without breaking?
3rd & 4th Photos: How do these nozzel connections come out? I gently pulled on them a little bit but there was no movement. I wasn't close enough and the light was bad, so I'm not sure exactly how these are connected.
After these three connections are loose will the tube just pull out from underneath the heat shield?
I'm trying to find out from someone who has done this before. I like the guys at this garage, but I know that they will just yank everything out if they can't figure out how to properly remove it in two minutes.
Clip that secures washer fluid line coming out of the engine bay on the passenger side
Passenger Side Connection
Driver Side Connection
