Who's changed their lift gate struts?
packweco
I've got droopy lift gate syndrome now that it's cold.
I'm torn because normally I would order the OEM replacements for something like this, but they are $180 a pop!
Anyone have good luck with aftermarket ~$30 ones from the local parts store?
Ya the aftermarket ones do the job. I did mine and they're super strong. You have to make sure the door doesn't pop up and hit you in the face but if you let it go up slowly, the aftermarket replacement struts hold the door up well
For engine/driveline components, always use OEM. But for this (since a failure won't cause life/death ;) ) I say it's ok to use aftermarket cheapies
Hey another Az 4runner guy, whats up. I like to do wheeling trips with local members if you are interested. Back to topic. I have not yet but need to since my rear hatch struts are doing the same as yours are, started with the cold weather. I will be getting aftermarket ones as well. I have installed many on different vehicles asll never had an issue.
I went with some clearance ones on Rock Auto once. Same as my old worn out ones. It lifts about 80% of the way and I have to push it up the rest.
I'm trying to decide whether to replace mine or not. Seems like they fully lift with the window up, but, with the window, down, the struts don't lift fully.
Should I expect the gate to fully lift even with the window down?
Thanks!
Thanks!
Those linked struts will lift it either way. A very controlled, full lift.
Yeah, my old ones only lifted about 90% so i thought new ones would do better, Nope same thing, its the overall design. Oh well....
See above. In a year and repeated use, I've never experienced anything but a full lock-out lift, and a controlled speed up the entire way.
I used frank from Strutwise in Canada. He rebuilt my oem struts, after shipping came out to about 150. Revalved for cold weather to compensate for the climate I live in now. 4 months and counting, very pleased so far. Picked up some junkyard spares for $10 to use during the exchange
Whatever you do, don't get Monroe Maxlift. I got those and they don't go up all the way in cold weather (I'm in SoCal...so cold is like 50F). Also, pretty dang hard to close the hatch. I'm a big guy so it's not that bad...but watching girls try to close the hatch is pretty funny.
No problems with Vato-zone struts on a wide variety of vehicles. When I start to get the "wont stay up in winter" problem, I just replace one strut and I've never found a need to replace the other.
Call me cheap.
Here are the ones I used:
Amazon.com: Qty (2) Toyota 4Runner 1996 1997 1998 1999 2000 2001 2002 Rear Hatch / Liftgate Lift Supports Struts Strong Arm 4286: Automotive
They fit and work perfectly - installed really quick and they do lift the tailgate all the way up with no problems.
The old ones (the original '97 ones) started getting weak in the bitter cold we had here in Phoenix last month (all the way down to freezing!!) so I shopped around and bought the ones from Amazon.
Like others have said, OEM only for important parts, but off-brand is fine for things like the lift gate pistons.
Ted
Just installed a pair of strongarm struts. $40/pair with free shipping from the ebay ad posted by [MENTION=104905]wake_rider[/MENTION] . Night and day difference. Today is a cold day and they go all the way to the top with gusto.
