Part number help: Oil filter housing gasket(s)
etc.
I have a 1997 4runner with a 3.4 that I believe is leaking oil from the filter housing. I have tried to search on Google, but I can't get a definitive answer.
Does anyone happen to have a part number for the filter housing gasket(s)?
here you go
90301-67004
RING, O
(FOR OIL COOLER)
90210-22001
WASHER, SEAL
I believe the post above has what you need. To explain, the 3.4 5VZ-FE does NOT HAVE an oil filter housing; the filters are spin-on type and the gasket comes attached to the filter. The oil COOLER looks sort of like a filter housing, and is mounted about 18 inches to the rear of where you should see the actual filter installed.
THANK YOU!
I guess if I referred to it by the correct name, my search would of been more effective.
:thanks:
