front receiver hitch
besche
I'm searching for front receiver hitch to fit factory original 2000 4runner SR5.
Can't find bolt-on unit.
Is this accessory available?
Some plate bumpers have a 2'' receiver built in (can't think of the exact models off the top of my head) but I have never seen a bolt on hitch for the 3rd gen. What use would you need it for?
I would seriously consider getting one, IF the hitch were mounted high enough to keep maximum ground clearance.
Why not get the ideal bumper that you want, and have a 2" receiver welded onto it? It would need bracing to be strong enough, but could be done.
The problem with receiver mounted winches it the winch usually will outpull the weight that the hitch is rated to.
I wouldn't want to trust pulling mine out of a hairy predicament relying solely on a 5/8" hitch pin to keep everything together.
Pulling at an angle just makes it worse as hitch ratings are linear.
well i beg to differ, as i have had both of my trucks pulled off the ground and being tethered by that 5/8" hitch pin... multiple times, and in some cases using a snatch block and still having the winch stall out, so thats what 19k lbs and still no 5/8 pin snapping or deforming...
one should never intentionally pull from an angle regardless of anchors, but i understand that this is not a perfect world. and yes several of my pulls have been off set or side loaded as well, but that would never affect the pin, that would come in more to the tongue of the receiver, and those are usually more than strong enough.
Here's mine on my FJ. Built by Hardline Fabrication in South Carolina.
They exist as they were manufactured by one of the hitch companies, for how long I do not know. Are not currently manufactured, according to all the searching I have done.
If there is interest in this I have to connections to make it happen. OP you should make this into a poll so I can give my source the info.
I want one, depending upon cost.
You know someone with a secret stash? Or who can make 'em?
No its company that is looking to make them. We started the initial design process already.
Initial design as in your buddy bought some sheet metal and starting welding something up? :p
I just couldn't resist. Ok I'm done being a smart aleck now.
Well not exactly lol, both of us working on it are mechanical engineers so... Yes of course!
But seriously I'll talk to him and see if he is moving forward with it.
comparing my bumper mounts (bumper is off) and hitch I assume this would require a combination of welding and bolting? are you trying for a bolt on style that requires no cutting or welding? My 99 Ltd seems to have an unusual bumper (fat lip?) making it the odd man out re bolt on front hitches. If minor mods were required I'd be up for it.
Draw-Tite #65041 - Front Mount Receiver - 500 Lbs. Tongue Weight-Weight Carrying - 9000 Lbs. Maximum Gross Trailer Weight-Weight Distributing - from Hitch Shop, Fort Lauderdale's #1 supplier of Trailer Hitch automotive parts & Draw-Tite auto acc
http://www.amazon.com/33025-Front-R...&newCar=1&s=automotive&vehicleType=automotive
Front Hitch for 2002 Toyota Tacoma - Draw-Tite 65041
Nope not him, are they still producing the hitches though? I just looked up 'Next Venture Motorsports" and didn't find anything.
didn't think it was your guy. thought you'd be interested. it is exactly what the OP was asking about and it is a different design + installation than I've seen in other front hitches. It is more compact, seems to not intrude into any clearance or component space. It's slick.
Gonna contact him (Dan) this week to inquire: if he has CAD he's willing to share, if he's willing to produce a kit with all the pieces in unwelded kit for, and if he's wiling to make one for me. [MENTION=111797]JohnJMonroe[/MENTION] 4R looks to be a 99 LTD, which is what I have, so there wouldn't be any 'fat bumper' fit issues.
Next Venture Motorsports |
