Center Bezel Lower Console Mod
Rock_Rat
Need some advise/suggestions:
I'm exploring different options of the mods I'm going to do on my center bezel and shift console;
First - I want it to look extremely professional. Basically a factory setup.
The following are the components I want to install:
Scan Gauge II
I want to be able to run the OBD connector behind the bezel. I also want to be able to read parameters easily while driving. The steering column makes the most sense but its unsightly.
Small but Quality CB Radio
I don't plan on buying a ham radio. If I ever need a Ham radio I've began going pretty extreme. I'm open to recommendations on a quality CB radio.
My own personal preference is a clean configuration. Ergonomic and easy to control while driving if needed.
12V Switches and panel
I'm looking to add a DC switch panel with about six switches, mostly for lights and what not. Ditch lights, fogs, rears etc. I've seen a couple of aftermarket brands out there (ARB, OEM, Blitzpro, AirOnboard) but would like your input. Ease of use, interface with the 3rd gen wiring, mounting etc.
What did you replace your 12V plugs and cigarette lighter with?
I've only seen [MENTION=55891]Bandit Runner[/MENTION] with exceptional use of plastic designed with CAD and solid works. Is there anyone who has modified their center bezel to factory standards? Also aside from the AEM gauges, what have you done to the blank space on the shift console.
I want to make sure I do it all correctly the first time. I didn't see an actual thread or anything in the Tutorial Documentation section.
As always...thanks!!
Just a few comments since you mentioned me.
Why would you want to get rid of the 12V DC outlets? i find that they come in pretty handy.
I think the Scanguage would be difficult to see if you put it down that low. I like the Scanguage on the steering column. I use if for my spedometer, so it is easy to glance at while not taking my eyes off the road.
Looking forward to seeing what you come up with!
And just to set the record straight: I design in Creo, not solidworks.
My thread has some ideas on where to out extra switches. Didn't get to the point of having to loose anything from the dash.
I put my radio in the ashtray space though.
I'm interested as to what you come up with. I want to mount a CB somewhere, but not the ash (trash) tray because I use it. I also can't do a single DIN mount under my radio because I have a drawer there that I use for stuff.
Very clean setup. This is exactly the look I'm wanting. So you've got me considering the handheld VHF instead of the CB. What are you doing for the USB adapters? Do you have a Scan Gauge mounted?
That's an all in one hand held Cobra CB.
USB adapters?
I never posted mine...
I have a "unique" switch panel under the radio, working ashtray, CB under the ashtray, and 2 12v outlets on the passenger side filler panel (not pictured)
This is my set up. I don't have a CB radio and it would be a tight squeeze to try to get one in there.
Both the switch panel and the scan gauge bracket are from paranoid fabrications. They were reasonably priced and very nice quality and he has shipped very quickly every time I've ordered from him.
Sorry for the crappy cell phone pic. I had just finished installing the switch panel when I took it.
00A30C99-C96B-457B-A5EC-E175E433A246_zpscequbmxl.jpg~original
This is cool. And looks great. But personally I wouldn't want to cut mine up. That said. There's a company called paranoid fabrication. They sell rocker switch plate that bolts up under the headunit. And also one that relaxes your ash tray into one.
