Originally Posted by micahp
Yes it powers on and the antenna goes up but no sound
Is it running through the factory amp as stated above?
Did you wire the stereo harness directly to the 4runner wires? It doesn't look like you used an adapter. As stated above I would get a Toyota stereo adapter and wire that to the wire set that came with your stereo from Walfart. After that its pretty much plug and play.
Also that wiring looks in rough shape I would get that cleaned up and SOLDER your wires and heat shrink each one. If you bought from CLUTCHfield it would have a wiring diagram that you cross reference with the one from the radio.
Its a long shot but just out of curiosity does the stereo have a muting button for taking calls?
