Rear driveshaft skip yoke grease fitting size?
JBurt
I sheared mine if on a gas tank. Anyone know the size offhand? I can't find a match in my box of small bolts.
edit: the title should say slip yoke. Blame autocorrect on my phone.
Are you running the shrockworks skids or stock ones? I thought you had the shrockworks ones and I figured they would have more clearance, but I could be wrong.
I think they are 6mm zerk fittings, but I'm not 100%.
I do have the shrockworks skids, but I haven't put the gas tank skid on yet.
Thanks for posting about using the factory tie downs. I had actually done the same thing right before I saw your post. Hopefully they have enough beef to them to get us unstuck until I get some other recovery points.
Alright, I was getting kinda worried for a second haha. I think they should work for the time being. You can even run the factory hook instead of just the loop, but I chose to leave that off.
When you do the gas tank skid make sure to leave the center bolt in at the front of the tank as it doesn't hold the skid up, only the tank... That was the only issue I had installing it.
Do yourself a favor and use these for day to day, and put the zerks on only when servicing. I got tired of extracting the broken ones, these sit flush inside the housing. I did have to try a couple different lengths before i found the one that seated properly. I think i settled in 8mm but not 100% on that.
