02' Sport "Small Build" (Build Thread w/ pics)
Grey-Thunder
02' Sport "Build Thread" (Pic-Heavy)
2002 Toyota 4Runner
Sport Edition
Thundercloud Grey Metallic​
I have always been a member of the forum but I finally decided to create a build thread of my own. I have had my 4-runner for about 4 years now. When I bought the 4-runner it was completely stock, 2 owner, and it had 193,000 miles. This is my Daily Driver and it currently has 225,000 miles. Since its my daily driver, i'm shooting for a weekend off road vehicle while still being economical and practical as a DD.
When I bought it:
As it Sits Now:
Modifications:
Engine
-Deckplate mod​
Suspension
-OME 881 Front coils/OME 906 Rear Coils
-Front Adjustable 5100 Bilstein Shocks (Top Notch)/ 5100 Rear Bilstein shocks
-1.5" Daystar Rear Lift Block
-AirLift 1000 Rear Air Bags
-1" Toytec Diff Drop​
Wheels/Tires
-Stock Rims
-265/75R16 Goodyear Duratracs
-1.25" Spidertrax​
Exterior
-Brush Guard
-TRD Sport Decals
-LED Taillights
-6" IPF Off-Road Lights​
Interior
-Kenwood Excelon Single Din Stereo
-Polk Audio Speakers
-Dual 10" Powered Sub​
Future Mods
-ISR Mod
-Andy-mod 2.0
-DRL Mod
-Window Tint
-17" MK6 Level 8 wheels black
-285/70R17 Goodyear Duratracs
-Tundra Brake Upgrade
-Rock Sliders​
2 in" Lift Installed and tires
OME 881 & 906 Coils w/ Bilstein Shocks also 265/75R16 Duratracs installed
Sorry I don't have many pics of the install I didn't take any
Before:
After:
TRD Decals
Toyota should have put these from the factory, they look like they were meant to be there.
Added more Lift
Sorry, right now I'm a little out of order with my mods, I'm just trying to catch up.
Before Lift:
Bilstien shocks were adjusted to the top notch and 1.5" Rear block lift and Airbags were installed
Rear Lift and Airbags
I cut the bump stop off completely and this is how I installed the airbags in the spring
I mounted the air nipples behind each mud flap, I didn't use a T connector because i wanted to be able to adjust each air bag in case a load was heaver to one side
More Lift Added
Rear Lift finished
Finished
1" Toytec Diff Drop Installed
Before:
After:
Deckplate Mod
Deckplate
Installed 1.25" Spidertrax
Before:
After:
Installed Grip Tape
I had some grip tape laying around so I said why not :biggrin2:
Off Road Lights Install
So I installed the 6" IPF Off Road lights on the Brush Guard
the harness that came with the lights was a plug and play harness:
I mounted the relay next to the battery for easy access:
Since I wanted to turn on these lights anytime I wanted, I used a fuse tap and tapped into the dash lights fuse instead of tapping into the high beam lights
I didn't like the cheap switch that came with the lights so I cut the wire to that switch and I bought a GB Rocker Switch, it took me awhile to figure out the wire combinations but I finally figured it out
Finished:
I also recieved my CB antenna mount from MStudt
Installed CB
I finally had the time to install my CB!
I used a 90 Degree coax connector so I could mount the CB further in the dash
CB Antenna Installed
I used the mount from [MENTION=98153]MStudt[/MENTION] to mount my 4' Firestick Antenna.
Just a Few Pictures
Got a Benelli for Chirstmas
