Originally Posted by Beagle(4)Runner
Thanks for the information. Why do i remove the factory amp if I am not installing an aftermarket one, do I not need it?
Your new head unit will provide plenty of power for your speakers. Furthermore, the adaptor plug will not mate with the amp output harness. You need to plug your hand-built harness into the vehicle's plug to the amp.
If your power antenna still operates, you may consider mounting a dash switch to eliminate the constant up and down whenever you start or stop your vehicle. This switch is wired between the blue wires of the two harnesses.
And, if you have the window antenna in the right rear window, you have the dual antenna and you will need a couple other bits. There are two antenna leads to the factory head unit with this setup. One is the common 1/4" Delco or Motorola plug, and one is a micro antenna plug. A y-combiner will be needed (Metra 40-UV43) and a micro/Delco adaptor also (Metra 40-gm12).
Bestbuy usually has this stuff in stock, or you can buy online via the numbers provided.
