For those of us with high-mileage vehicles, carbon build-up starts to become an issue. There's a lot of us that use seafoam both in the gas tank as well as poured in through the intake. I normally put it through the intake to break down carbon.
I've tried using the Seafoam Spray with great results, even better than the liquid seafoam. It comes with a straw and clip that fits between the air intake and the throttle body that makes sure it is atomized and distributed to all 6 cylinders, unlike the liquid which depending where you use it may only go to a few cylinders.
I had a rough idle lately I could not clear up. Checked spark plugs, wires, boots, oil, etc. and no go, still was there. Remembered I had half a can of Seafoam Spray left and guess what? Rough idle gone. It's easier to use than the liquid too, I recommend it since the spray goes exactly where you need it.
If you have a few min, this video shows very well how well it works and what it does (has before & after of pistons).
Let the flaming begin!
Any way you can post a picture of where exactly you sprayed between the intake and throttle body?
Edit* just saw the video srry
When I eventually get around to doing this, I fully expect my retarded neighbors to call the fire dept on me.
My neighbors hate me so bad. Flood lights till 2am. Jack Stand tuning turbo 4 banger in garage. Seafoam clouds. Air compressors and Grinding. They hate the crap out of me.
TILL THEY ASK FOR HELP ON THERE CAR.
__________________ 1996 Toyota 4runner Limited - 4" Lift, 33's, AOR Bumper w/winch 1990 Eagle Talon Tsi- E316G @ 32psi E85 Tuned, 272 cams, ECMlink v3.0, 405whp - Gave back to Brother 2012 Toyota Tacoma DCSB - Stock on 32's- Wifes 2004 Cadillac CTS-V - 5.7L LS6 v8, 6-speed 400hp/400tq - My new DD http://www.toyota-4runner.org/3rd-ge...read-pics.html
Happened to my brother and I sea foaming his old Accord. Let's just say they were less than pleased. Cops that came with that it was hilarious, which was a plus.
Distilled H20 is much cheaper and great at decarbing.
That's how my Dad showed me to do it with the old carburetor equipped cars. We've used water or ATF with great results. Used ATF the same way we use sea foam now.
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Maxxis MT-762 Bighorn 255/85/R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
Mine hate me too surely, they'll get over it though.
And then you go help them change brake pads. They somehow make it out of the neighborhood without touching the brake pedal, and almost cause an accident at the intersection because the pistons hadn't pressed all the way back out yet. How one doesn't check their brakes before getting on a major road after working on them I will never know...
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles 2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles 1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
Thats the reason why I always do "brake check" right after i change brakes
Slam on the brakes a couple times to make sure everythings good to go
and since its a 3rd gen, your brake check automatically warps the rotors...
__________________ 1999 4Runner SR5 Highlander V6 4WD ELocker 2008 Toyota 4Runner LTD V8 4WD
2000 4Runner SR5 V6 4WD- Sold
"Why do people measure life by the years, and not by how good the years were?"
Just seafoamed my old Taurus tonight through one of the vac lines. Thanks for posting this thread! I too had a slight lumpy idle and it seems to have cleared up.
Haha! I did this the other day and a couple of my neighbors came out of their house quick to see what was going on. Oops. Guess I shoulda said something.
"FAM4RNR" 2000 SR5 4wd, Rear diff lock, ome 881/890, bilstein 5100s, toytec panhard bar drop, revtek front diff drop, firestone AT 265/75/16
With this method of spraying it into the throttle body don't you run the risk of it getting into your Throttle Positioning Sensor and fouling it?
I know this happens when people clean their throttle body so I would imagine it would be risky with this type of treatment
2000 "The Silver Legacy 2" Highlander Edition, 5speed 4x4
2000 "The Silver Legacy" Highlander Edition, 5speed 4x4 RIP
1996 Stellar Blue 5 Speed Sold
