Flemster's 2000 SR5 Sport
Flemster
2000 TOYOTA 4RUNNER 4x4 SR5 SPORT EDITION
SILVER
3.4L V6 5VZ-lFE
4-Speed A340lF Automatic Transmission
4x4
4.30:1 Differential Gears w/ E-locker
an offroader who happens to own a rooftop tent.
Most recent pictures as of Feb, 2020:
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/49406055283/in/datetaken/" title="9A0A2834"><img src="https://live.staticflickr.com/65535/49406055283_f32e095896_z.jpg" width="640" height="400" alt="9A0A2834"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/140899154@N02/49290414811/in/datetaken/" title="9A0A1379"><img src="https://live.staticflickr.com/65535/49290414811_2ddd9d0b38_z.jpg" width="640" height="427" alt="9A0A1379"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/derpiful/49081964943/in/datetaken/" title="IMG_0674"><img src="https://live.staticflickr.com/65535/49081964943_be208fd36f_z.jpg" width="640" height="427" alt="IMG_0674"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
UPGRADES & MODIFICATIONS
Suspension:
Front:~0.5" lift
King Extended Travel
600lbs Coils
SPC Upper Control Arms (Set at F for clearance)
Plastics Guy Front Duro Bumps
Rear:~2.5" lift
-OME 861's
-4th Gen Extended Travel Bilstein 5100's
-Plastics Guy 5.25" Duro Bumps
Wheels & Tires:
-Stealth Custom Series F5's in Gloss Black - 16x8
-315/75/16 TreadWright Guard Dog M/T (firewall chop for clearance)
Load range "D"
Engine & Performance Upgrades:
-Deckplate Mod
-Airaid Intake Elbow
-OEM filter
-Transmission Cooler
-PVC Washer Fluid Reservoir
-Trail Gear Bomb Proof Motor Mounts
Undercarriage / Drive Train Upgrades:
**Front End**
-Tundra 231mm Brakes (13WL) (power stop rotors)
-4.30 gear Ratio (Planning on 5.29)
-1.25 Hubcentric Spidertrax Wheel Spacers
-Toytec Poly Steering Rack Bushings
**Rear End**
-Factory E-locker: 4.30 gear Ratio
Electrical Modifications:
-Rats nest for lights and winch
Interior Upgrades:
-Sherpa Equipment Co. PAK System Drawers
-Transmission Temp Gauge (A-Pillar)
-Oil Pressure Gauge (A-Pillar)
-Scan Gauge Mounted behind the steering wheel
Stereo/ CB/ HAM:
-Kenwood Double Din Touch Screen
-Esky EC170-06 Backup Camera
-Pioneer Premium speakers
**CB Radio
-Midland MXT275 in the ashtray
Exterior Upgrades:
-Matterhorn Roofrack from Sherpa Equipment Co./URL]
-Tepui Explorer Series Ayer 2
-20% Tint all around
**Exterior Lighting**
-Custom Retrofits from SRQ Fabrications
- D2S 2.0 35W Ballast and 5500k Bulbs. Apollo 1.0 Shroud w/ 90mm Switchback Halo
-LED Tail Lights (Black) (Eagle Eyes)
-LED Front Turn signal under the headlight
-Element Canons as Fogs
-X6S Slim Series 2D Amber White 38" Single Row
-12" Extreme Led Dual Row
-Two Amber Stackerz from Extreme Led on Flasher Relay as Chase Lights
**Armor**
-Low Range Offroad E-Locker Skid
-Custom Rear Lower Control Arm Mount Skids
Stock Lower Control Arms with Angle Iron welded on as skid/strength
-Lil' Skips Gas Tank Skid
-Addicted Offroad Sliders
-Addicted Offroad Tube Front Bumper
- SmittyBilt X2O with Cable
- Factor 55 Pro-Link (Blue)
-4x Innovations Rear Bumper with Swing Out and High Lift Mount
(Powder coated Textured Semi Gloss)
-4x Innovation Front Diff and Transmission Skid
Ill try and keep this thread as Updated as possible and keep the images coming!!
Eagle Eyes Tail Lights
Decided to replace my stock taillights for the black finish Eagle Eyes LED Taillights from Ebay
96-00 Toyota 4Runner SR5 Base Limited Black LED Tail Lights Lamps 1 Pair | eBay
First I uninstalled the old tail lights, You have to take out the rear piece of trim inside the back with the 5 screws. Then the one around the dome light for the rear. Then I just popped the side panels out enough to fit my hands in to unplug the lights and unscrew the ground. The ground bolt is 10mm. (Be careful with the plastic pins, they break very easily. I would recommend using a body panel clip tool or a putty knife)
IMAG0133_zpsmnd1uz4v.jpg~original
IMAG0134_zpsk6tdh7dt.jpg~original
IMAG0135_zps7sbpzuha.jpg~original
Here are the old Taillights, I did not get a picture of the New ones before I put them on the car because UPS showed up at 8 and it was dark outside.
IMAG0136_zpssevuhkuf.jpg~original
I got the new lights Installed and everything buttoned up again in about 20min, the whole project took about 40 minutes MAX. Remember to reattach the ground wires, and check to make sure everything is working before closing it all up again. Here is the finished product, I love the way they look and they are much brighter.
[/IMG]
IMG_8907-1_zps7xzgajeg.jpg~original
IMG_8908-1_zpsfdtf8ewm.jpg~original
IMG_8919-1_zpszqzbihx7.jpg~original
IMG_8924-1_zps8kq1xiah.jpg~original
Day Trip Yankee Hill (3/6/16)
Yankee Hill
Had some fun with some local Toyota buddies!
IMG_5566_zpsxbiok8zd.jpg~original
IMG_5582_zps70iskpdv.jpg~original
My friend is a "pretty boy" and likes to pose!
IMG_5670_zpspyqzqvrm.jpg~original
IMG_5607_zpsdhb9y2mx.jpg~original
IMG_5688_zpsraq8j3v5.jpg~original
IMG_5686_zpsongvawn0.jpg~original
IMG_5732_zpsdvtru1ld.jpg~original
It's about time man! Glad to see you have a build thread. I've been following you on Instagram for a while now, you do nice work! Keep it up! Subbed for sure!
Is it cool if I jack more of your pics and use them on my Instagram? I won't give you any photo cred of course.
Yes please!! Be my "Savior" if you will [emoji52][emoji19] That guy needs his paged taken down ASAP! He blocked me and [MENTION=99717]Limbwalker[/MENTION]_
Glad to see you finally have one of these, welcome to the build thread club!
Yeah, that account/guy is so dumb. I really wish Instagram would actually do something about it.
Some More pics of the Runner
Update
Taken after I put on my 1.25 Spidertrax Wheel Spacers from [MENTION=120787]Bijan[/MENTION]
Photo that [MENTION=120787]Bijan[/MENTION] snapped of me on Yankee Hill, Love this one!
Some flat ground pics!
Super Excited to get this bumper in a few Weeks from 4xInnovations with swing out and plan to make a quick little mount for rotopax next to the tire!!
Repainting my front bumper after some harsh winter driving, it was much needed. Ill get it all back together in the morning!
Hey man, nice looking rig. How do you like running 265/75's with 3" of lift? I'm contemplating tire size to go with my lift.
