3rd Gen T4R DIY Maintenance, Repair and Modification Videos
Take another look at the video. We routed it just like the decal. The decal shows a static pulley rather than the dynamic one Sean bought. I'm pretty sure the belt can only go on one way to work correctly. We're glad you like the video.
**Edit I just watched the part of the video where we get the belt in place and you are correct. The routing we did is different than the decal. The decal is obviously showing the routing for a fixed supercharger pulley and not the dynamic tensioner Sean bought for this job. Thanks for pointing this out to us.
Maybe the different pulley is what was different, I just thought that the decal was showing that the belt from the alternator went to the blower pulley then wrapped around the idler which looks like it would have cleared the dipstick.
No offense intended ( if any was taken ) just trying to clarify. I enjoy the vids because you show the FSM and use that as your guide instead of trying to figure it out as you go.
No dude, you were absolutely right. No offense taken. I edited my first response to say you were correct. The decal in the video shows the proper routing if you have a STATIC pulley. Sean bought the dynamic tensioner so the routing has to be different. Thanks for catching this and letting us know. I added a pinned comment to the video letting people know this.
Do you have water dripping from areas of your headliner? Do you have a sunroof in your vehicle? If the answer is Yes to both questions, watch this video to try to isolate where your leak is coming from. It could be because you have clogged sunroof drains that need to cleared.
You can clear your own drains with a little persuasion from weed whacker line or some other type of solid line you can snake in the drains.
**In the video, I say the driver side rear drain travels down the B-Pillar but it actually travels down the C-Pillar and then over the wheel-well.
**Some people have employed the use of compressed air but you need to be careful if you choose this method. If you use too high of air pressure, you could force the drain tube off the fitting and then you'd be forced to pull down your headliner so you can reattach the drain tube.
<iframe width="560" height="315" src="https://www.youtube.com/embed/qalXo4etX3Q" frameborder="0" allowfullscreen></iframe>
IDK Tim, that seems like a lot of work. Caulking might work better
https://vancouver.craigslist.ca/van/cto/d/1998-4runner/6490831294.html
Damn, never been into this thread, but holy moly you guys have been cranking out the DIY's. I'm sure a lot of people will continue to find these very useful. My brother in law knocked out the timing belt on his car using this kind of video. Props to you guys.
Sent from my Z981 using Tapatalk
Automatic Transmission Filter Replacement
Here'a a video showing you how to replace the automatic transmission filter on your A340F transmission.
<iframe width="560" height="315" src="https://www.youtube.com/embed/tuGazNhuEtM" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Fuel Sending Unit Replacement
In this video we show you how to drop your fuel tank, remove the fuel bracket assembly, replace the fuel sending unit and get everything back together. The steps we show in this video would be all the same steps if you had to replace your fuel pump.
<iframe width="560" height="315" src="https://www.youtube.com/embed/GrzX_K-jcuo" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Thanks for taking the time to collect all these and make the thread into a "one stop DIY shop" Great reference
Ridiculous how clean California trucks are
You're welcome. But, [MENTION=102606]infamousRNR[/MENTION] and I actually made most of these videos. So, there's actually a lot more CREATING than collecting going on with this thread. If you like what you see, you should subscribe to our channel. If you like what the other YouTubers contributing to this thread are doing, you should subscribe to them as well.
Here's a link to our channel. https://www.youtube.com/channel/UC9EMiD9KPy61kJ6hdXcbjxA
Timmy the Toolman
wow
Thanks guys, I know how much time you have to invest in this, and I appreciate it! I'll be using your vids, I've got some maintenance coming up this Spring...
LCA Bushing Replacement Part 2
Hey Dudes,
[MENTION=102606]infamousRNR[/MENTION] made a Part 2 video for this repair due to the fact we know sometimes the cam adjuster sleeves can get rusted into the bushing sleeve and also due to the fact some people have managed to destroy their LCAs using the bottle jack technique.
Here's the video and Enjoy the Show!
<iframe width="560" height="315" src="https://www.youtube.com/embed/6FzEHygizoI" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Automatic Transmission Temperature Gauge Installation
Hey Dudes,
If you have a 96-98 3rd Gen with an automatic transmission and want to monitor your trans temps, you need to install an aftermarket gauge because trans temp info isn't available from the ECU.
Here's a video showing you how to do it.
<iframe width="560" height="315" src="https://www.youtube.com/embed/fT_2szdKXRM" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Tim, have you thought of tackling the double cardan joint on the rear driveshaft? Thanks for continuing to make the DIY vids, they have helped me on a few occasions as well as countless other people.
1 Million Views for the Timmy the Toolman Channel
Hey Dudes,
We thought we'd share a milestone with Y'all. It took us 2 years, 1 month, and 19 days to finally hit 1 MILLION VIEWS. Also in that time, we created 69 videos and have attracted approximately 6400 subscribers. Sean (aka [MENTION=102606]infamousRNR[/MENTION]) and I are proud of what we've accomplished so far and we appreciate the support that we've gotten from many of you on this forum.
Sick Mods for All!
Timmy the Toolman and Sean
I thought about it but the replacement parts are hard to source and the ones you can find are supposedly inferior to OEM. Most people just opt to buy an aftermarket driveshaft like one from Tom Woods.
Hey Dudes,
Sick Mods for All!
Congrats! Thanks for making videos worth watching a million times.
