Originally Posted by amalik
one of those amazon reviews says they are using that solenoid instead of relays..
seems like that's not a good idea
In actuality a continuous duty solenoid is simply a very heavy duty relay. You are using a low current circuit to activate, or trigger, a higher amperage circuit. I have used those continuous duty solenoids with great success since the early 80's. I used them in lieu of isolators that were diode based and prone to failure.
In the modern world we live in isolators have improved, such as the one used in the "Luna" kit mentioned above. I still don't like isolators and prefer solenoids. There are now smart solenoids that will delay the connection until after the voltage in the primary batter stabilizes after starting.
https://www.waytekwire.com/item/7705...iKMaAhwZ8P8HAQ
This one has the ability to be triggered for jump starting yourself. And is rated at 200A. Other brands you could look at are Blue Sea, Intellitec, and True. RedArc as well, but I think they are Australian and hard to get stateside.
Edit: This is another one that I recommended to a friend
http://www.powerstream.com/battery-isolator.htm
