OEM Part numbers
GHARP57
Maybe if wanted I can create a sticky thread and get it updated as I go along for requested Toyota part numbers for 3rd gen stuff. Ill update as i go along or get requests for popular items
5VZ-FE Plugs and wires
90919-01192 plugs x6 3.13
19037-62010 Wires
Highlander Springs
48231-35210 Rear Springs x2
48131-35400 RF Spring x1
48131-35350 LF Spring x1
Upper Ball Joints
43310-39016 x2
Lower Ball Joints
43340-39465 Left
43330-39585 Right
Engine Refresh 5VZ-FE
17176-62040 GASKET, PLENUM, 2 13.22
11188-62010 PLUG, CAMSHAFT HOUSING 2 12.15
90311-38051 SEAL, OIL(FOR CAMSHAFT SETTING) 2 13.25
11213-62020 GASKET, CYLINDER HEAD COVER 1 31.51
11193-70010 GASKET, SPARK PLUG TUBE 6 3.48
90311-A0027 SEAL, REAR MAIN OIL 1 44.74
12204-62010 VALVE SUB-ASSY, VENTILATION 1 12.38
90480-18001 GROMMET(FOR VENTILATION SYSTEM) 1 5.55
90311-40022 SEAL(FOR OIL PUMP) 1 11.90
13568-YZZ03 BELT SET,TIMING 1 58.57
13505-62070 IDLER SUB-ASSY, TIMING BELT, NO.1 1 163.92
13503-62040 IDLER SUB-ASSY, TIMING BELT, NO.2 1 122.49
13540-62021 TENSIONER ASSY, CHAIN, NO.1 1 56.14
90210-22001 WASHER, SEAL 1 5.03
90301-67004 RING, O 1 4.97
16100-69398-83 WATER PUMP ASSY 1 136.76 136.76
16325-62010 GASKET, WATER INLET HOUSING, NO.1 1 6.35
90916-03075 THERMOSTAT 1 26.47
16571-62070 HOSE, RADIATOR, NO.1 1 21.57
16572-62090 HOSE, RADIATOR, NO.2 1 21.47
90080-91090-83 BELT,V ALTERNATOR 1 23.12
90080-91126-83 BELT, V-RIBBED 1 19.92
99364-20870-78 V-BELT 1 24.13
