Power window switch repair
glockman
My passenger side power window switch has not worked very well since I bought my 4 runner. Well, this week I got tired of my wife asking if the child lock was on so I decided to tear into it. I had looked at used switch panels and people wanted a more than I was willing to spend. Plus who knows if they would be functional. The unit new is a couple hundred bucks so that was out too. Most power window and lock switches I have torn apart are very similar.
Here is how I repaired the switch
I took the panel out of the door by prying up on the front of the lock/window panel. There is a metal clip that holds the front down and a tab at the rear that slides under the door panel. So lift the front up and slide forward.
Once the switch panel was out I removed the power window switch by prying the tabs out on the bottom while pushing the switch out of the bottom.
This leaves you with the actual window switch which is made of a black upper piece and a white lower piece. I removed the white lower piece by pushing in the tabs on the side while pulling it away from the upper (black) portion
This is what it looked like once it was apart.
You can see in the picture all the carbon buildup. I cleaned this off with some electrical parts cleaner and 200 grit sand paper. Put a dab of grease on the arms inside the black portion and put it back together. Works like a charm now.
Nice, for what it's worth the guts of that switch are just like my 89 FJ62. As usual Toyota doesn't change things very much for no reason like some manufacturers (cough Honda). One of the reasons I love Toyotas.
This means most likely 3rd gen switches can be used for parts, I have destroyed the master switch on my FJ62, and Toyota does not sell it, and it was $400 when it was available. The A/M replacement was $150 and it fell apart very quickly. Sadly the newer Toyota models use and ECU so don't run heavy amperage through the switch, meaning I can't just swap in a master switch. Maybe I could figure out how to use a 3rd gen Body ECU AND the switch. Not this summer though, too many projects!
:naughty:
Thanks for posting. My switches all work but nice to have a link available in my master T4R folder on my desktop.
