07-12-2016, 11:06 PM
SPC UCA Alignment Sheets
Here's mine. Been a sh!tty day... I dropped it off yesterday to install my UCAs and an alignment. They didn't even start on it till noon today. They close at 5pm and they finished at 5:15. At you can see the Alignment is correct, but it isn't "right". I have a lot of miles to put on in the next week and then I'll be away for about a month working on the Slope, so I needed to get these done ASAP (that's why I didn't install them myself).
I told them to start with setting "D" (which they did), but during the alignment, previous shop tightened the crap out of my cam bolts. Driver side needs to be replaced (verge of being totally stripped), and the Pass side took a 36" breaker bar to loosen the back nut. Took, at times, two people with three hands and tools to get the driver side bolt adjusted. We got it this close, but without spare cam bolts on hand we were reluctant to work them too much. Now I have rubbing worse then what I had with OEM. We would've worked on it more, but I was just running out of time.
So what I'm asking is, can you post your alignment sheets on here to give them an example of where Caster should be to eliminate the rubbing at the back of the wheel well? What's the "Best" setup for our 4Runners with 2 1/2" to 3" lift and 33" or larger tires? I have a BL to install on here still, but if I ever run 35s, I'm going to have to push my Caster up. But how far before you really sacrifice drivability? I see on the 5th Gen Forum, they're going all the way up to +4* and claim it's perfect. Is it the same for us?
I'll add pics of my 4Runner in a few.
Thanks Everyone!
PS. Found out my rear end isn't square, so that can explain why after 3 alignments over the years it still wants to pull to the right....
07-12-2016, 11:33 PM
Pics of mine (again, I have 255/85x16 tires. Basically a 33x10)
Pass. Side
Driver Side
07-13-2016, 01:06 AM
I have 285/70r17 33's. SPC UCA's with new upper ball joints. Here was my spec sheet after the lift on April 2015 but before the 1" body lift. I didn't do the body lift until August 2015 after I received my bumper. No rubbing after adjusting the coil-overs. I had to trim the contura mud flaps on that lower inside corner. More than what's in the photo.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
07-13-2016, 02:01 AM
It just dawned on me.... (I've been going through every step they did in my head). We started off on the "D" setting like we should've, but then he did all the adjusting down below for the Camber \ Caster. I believe we should've:
1. Started on "D"
2. Zero out the stock cam bolts
3. Adjusted UCAs for Camber \ Caster
4. Fine Tune if need be back on the lowers.
Yes? No?
07-13-2016, 06:25 AM
On my Tacoma I started with the recommended setting (3 " lift but not running real big tires) with all the factory cam bolts in a neutral position. He set the caster with the factory cam bolts, then set the toe and finished the fine tuning of the camber with the upper uca ( had one side that was just slightly off). I ended up exactly with factory settings. I don't need the extra caster on mine because i never drive on the highway. I don't think there is anyway to adjust the caster without using the factory lower cam bolts and the initial setting you put it on
07-13-2016, 08:18 AM
I had exact same issue. D setting and rub rub rub. The issue is finding a shop to fine tune. I had to go to the most positive caster setting. A I believe. Then you can max out lca bolts and adjust camber up top. But truck needs lifted off tires for that adjustment. Shop don't like doing it. I was able to get 5* caster with zero rub. Went to three shops last alignment. They only got me 4* and slight rub now. I'm about to spend $500 on garage alignment kit. Tired of fighting with shops.
07-13-2016, 09:36 AM
I may be the only one with my spc uca's on the "G" setting. It pushed my front wheels as far away from the pinch weld/rear front wheel well as possible, then my caster was set using the lower cam bolts. This completely eliminated my pinch weld rubbing with my 315s (with daily driving).
I've gone through D-G on the spc uca's with MANY alignments in between to test what would work the best for my set up. My caster on G is 1.5 driver side and 1.7 passenger side. This is less then the factory specs but my toe and camber are within factory specs. I chose to stay with the G setting and give up some caster because it gave me the best rear front wheel well clearance without having to hammer on anything and didn't notice a compromise in drivability compared to the other settings i tried.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
07-13-2016, 09:51 AM
That is crazy, I have tried this and it pushed back the tire into the wheel well. But again I have found some tacoma guys will run like this but those LCA bolts have to be pretty much maxed. This is why I want to buy my own alignment kit so I can fine tune myself. So hard to get a shop to listen to what I tell them to do.
07-13-2016, 09:58 AM
Pass. Side
Driver Side
Are those the TOYO's? If I recall, they are a particularly tall 255.
1997 SR5. OME 906 rear, D558 bilstein front. 265/75 GY duratracs
2000 SR5 premium. E-locker, 2nd Gen SC. Shrockworks Front bumper. - current project.
07-13-2016, 10:20 AM
Luckily, I do my own alignments! This is what I believe to be the best possible outcome for my truck. 3" lift, 35"s, setting D, I forget what I set the lower cams to but I know I spent 2-3 hours getting everything all setup. Lots of ups and downs the rack. I opted to push my wheel as far forward as possible without sacrificing camber.
The 4Runner does not actually drive. It simply rotates the Earth to your desired position.
07-13-2016, 11:16 AM
Thats odd that on G your wheel was pushed into the rear front wheel well. I could see the slight forward shift of the tire away from the rear front wheel well when i asjusted mine to G. I did this bc thats what spc recommended to get the most clearance from the pinchweld area when i called.
07-13-2016, 11:38 AM
I remember you posting this before. I even talked about it at the garage...
Sent from my SM-G920I using Tapatalk
07-13-2016, 11:41 AM
This is the info i want. We start and document this and have a baseline to eliminate wheel rub. So we can go the a shop and say "step 1... this. Step 2... that......" each truck is different but that would be a start.
Yep. Toyos.... I believe it's more like 33 1/2".
07-13-2016, 11:44 AM
This is what info I need. And how does it drive? Sterring response? Self straighting? Does it fight you?
