Originally Posted by Majindan
Do you thinks it's just for the Elocker? My SR5 has the center locker, but I have no idea what else this could be for lol. Google sucks btw.
This truck didn't come with one. I swapped it in. Sorry to distract from the matter at hand.
Here are the pictures. I don't want to use the /img tag because I think it'll clutter your thread.
Diaphragm on throttle body (circular thing, center of frame down and to the right of the electrical connector):
http://i1383.photobucket.com/albums/...psogzwitrd.jpg
Small pipe as it meets the 60mm vac line to the intake manifold (your intake manifold vac source is capped). Also notice the thicker aluminum pipe that's sandwiched between the two smaller pipes. Yours doesn't have this, I'm guessing because it's a newer engine and it makes use of a rubber hose vs. rubber to hard to rubber - the brochure picture of the 2002 5VZ-FE in a 4Runner shows a configuration like yours, so I wouldn't sweat the fact you don't have this hard line on your intake manifold:
http://i1383.photobucket.com/albums/...ps2wrv9w29.jpg
Another view of the diaphragm and the 170mm vac line. Also again notice the thicker pipe that yours doesn't have as it connects w/the rubber line and makes its transit to the throttle hose pre-throttle body:
http://i1383.photobucket.com/albums/...pspmliimc9.jpg
