Chas of MRT
The long awaited Bilstein 6112 coilovers for the 3rd gen 1996 - 2002 Toyota 4Runner is almost here. Bilstein 47-258624 is the newest release of the 6112 featuring a staggered circlip with 9 adjustable height settings to dial in the perfect height on a massive 60mm shock body. Designed for the serious off-road adventure seeker, the all new Bilstein B8 6112 kit is the ultimate suspension solution. The Bilstein B8 6112 kit optimizes off-road and on-road capabilities with a 60mm digressive piston for increased damping control. This kit features specially designed cold wound springs and an adjustable spring seat which allows for vehicle leveling, larger tires, and increased ground clearance. The kit comes with (2) 60mm shock absorbers (2) springs and (2) billet spring seats. Bilstein B8 6112 kits are a direct bolt on for late model half-ton trucks and SUVs which utilize a front factory coilover suspension design. The Bilstein B8 6112 kit is for front applications and reuses the OEM top mount and spring isolators. To maximize performance, Bilstein recommends a B8 5160 remote reservoir shock absorber for the rear application which will be released soon.
Bilstein 47-258624
Kits available from MRT Motorsports.
Front 6112 Only - Bilstein 47-258624
Front 6112 / Rear 5100 - Bilstein 47-258624.24-249966
Front 6112 / Rear 5160 - Bilstein 47-258624
Front 6112 / Rear 5100 / DayStar 1.5" R Spacer -
Front 6112 / Rear 5160 / DayStar 1.5" R Spacer -
Front 6112 / Rear 5100 / OME 2890 Rear Spring -
Front 6112 / Rear 5160 / OME 2890 Rear Spring -
Bilstein 47-258624
