01-18-2017, 01:35 PM
#16
in. great thread so far. what beach did y'all go to? would love to find something not far and do the same for the weekend. especially one that isn't overly crowded like your pics appears to be
01-18-2017, 03:59 PM
#17
Yeah good thread, im sub'd.
Besides the huge photos at the end, I switched viewing thread as a printable version, worked well.
I have similar plan as you, weekend trips with RTT.
Need to stiffen out and lift my saggy runner.
Thanks for all the input, trial and error you did so hopefully I wont.
:cheers
'99 LTD, stock.
01-18-2017, 06:50 PM
#18
:cheers
Thanks. Yeah I'm not sure why they are so big. Maybe I can figure out how to make them scale down. I don't find the OME 891 to be stiff at all, and they definitely sag with about 200 pounds on it
01-18-2017, 08:15 PM
#19
Thanks
This is Padre Island National Seashore (PINS) in South Texas, between Corpus Christi and Mexico. It's a great place to get away. The North island (North Padre, or PINS) is 60 miles long, well from the entrance to the beach. The first 5-10 miles are usually busier, the rest is pretty desolate. At the end of the island is usually busy as well, it has great fishing and the way the island is shaped bring fish into it's crystal clear water. Lots of sharks there too...
Other than at the ends its very private. The only concern is with Coyotes, both 2 and 4 legged variety.
01-18-2017, 08:50 PM
#20
Nice set up man, love the color!
OverlandNV
-2000 4Runner Build Thread
-2004 4Runner
01-18-2017, 09:10 PM
#21
Real Name: Scramble
Real Name: Scramble
Nice pick up for $3500. A 4R with a locker can easily go for 5G's. The color looks great in the pics but I know what rattle cans look like close up. LOL
I rattle canned the hood of my old Accord but ended up sanding it again & spraying it with real auto paint. ($55 for a pint) Came out great.
Nice dogs too, me & my girl + 2 dogs.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
01-18-2017, 11:27 PM
#22
Real Name: Hoodlm
Real Name: Hoodlm
Great write up. I think everyone should document their truck transformations. I enjoyed reading it. Good job.
2000 4Runner Limited, 2" ToyTec Body Lift, 255/85R16 Maxxis Big Horns, 3" Lift Bilstein 5100s front and rear, OME 891 rear springs, 4x Innovations Rock Sliders, Silencer MOD, Deckplate MOD, PlastiDip Guru, Total Chaos UCAs, ToyTec Adjustable Rear Lower Links and Panhard, Tundra Brake Upgrade
My Build Thread
01-19-2017, 01:07 AM
#23
Actually, the paint looks really good. No one knows it rattle can until I tell them. I sanded between coats, which seemed to help a lot. The only area that looks bad are the fenders, which I just painted to keep them from being green and the roof, which I really just lost interest in painting since its on the roof. Overall, I'm very happy with it. If I do repaint it, I may just take it to econopaint or something like that.
01-19-2017, 01:53 AM
#24
Nice build, great photos. I'm going to Plasti Dip my bumpers and lower trim when I replace the damaged front bumper.
01-24-2017, 10:09 PM
#25
New wheels
So after deliberating back and forth with the wife about which wheels to get, I decided on the Konig Countersteer Type X from FN wheels. They have a 4.1" backspace, vs the 4.84" backspace on the FJ wheels. I had initially thought the FJ wheels were maybe bent, but there were issues with one tire and another tire wasn't mounted squarely on the bead. I ordered these and got the tires fixed, which fixed the problem. I chose the Countersteers because they are 17x8, have a "low" backspace and they are crazy light.
The new wheels
I went to another, different Discount Tire after dealing with my local one and not getting what I want most of the time. I have personally serviced their Hunter balancers, and I know this shop takes good care of their equipment and calibrated them.
I also put new lift gate struts in the back and also put the TDI floor mats in. They turned out pretty good, the rear are great, fronts are OK fitment. Better than the carpet parts that were in there.
I also put a new fuel filter in, after having some prolonged cranking to start. As far as I could tell it was factory. Holographic Toyota sticker with a barcode. It was pretty nasty, but easy to do.
Also ordered some All-Pro Rocksliders. I like that they stick out farther than most of the other ones I've seen. That should make it easier to mess with the tent. No idea how long they take to make and get here, but hopefully not long. Plotting my first big trip....
01-25-2017, 05:47 PM
#26
Painted flares
02-03-2017, 06:38 PM
#27
Fixing the center stack and new radio
I had the 4Runner at Discount Tire again to get the tires balanced. I seem very having a major issue with something. I can not seem to get these F'n tires to balance, or there is some other issue causing vibrations. I've already addressed everything I can think of that could cause vibrations. I had them put the clamps on weights outside the lips, even though the guy said they will scratch. I care more about function over form and will not tolerate vibrations. It's significantly improved vs the sticker weights, as I figured the case would be. Static Balance is hard to do on truck tires reliably.
Anyway, while I was waiting for the balance I wandered over to Best Buy to see about upgrading the radio. The stock H/U sucks and I would like to have Bluetooth. I was able to pick up a nice Pioneer touchscreen unit with a Metra wiring Harness and some Pioneer 6.5" Speakers for the front doors for a hair under $300. Both the radio and speakers were open box items and looked unused. I experienced no issues during install, except the park brake sensor has to be installed to do basically anything on the pioneer unit.
I also used this time to replace my Center stack plastic with a black one, I'm not a big fan of the fake wood. Plus the limited fake wood is the thinnest cheapest plastic I've ever felt. It literally disintegrated in my hands. I got a black one from the junkyard and painted my middle section of plastic to match.
Crap "wood trim" that just fell apart
The middle piece of trim:
New radio, trying out the DVD function. Works great.
New door speakers
All done
I'm really impressed by the performance of the head unit. It's the Pioneer AVH-X3800BS and I used the Metra 70-1761. At Best buy the computer pulled up several numbers for the harness. This one connects the 2 separate wire sets to the one radio connection. I have the factory amp that I removed.
My All-Pro Sliders should ship today so next week I'll be putting them on, I'm excited about that.
02-05-2017, 08:42 PM
#28
Really like the look of the removed running boards.
02-05-2017, 10:26 PM
#29
I have that same Pioneer in my Ram and love it. Will probably put one in my 4Runner. I have had it for about a year and still find some new features on it. As far as the park sensor, go on Amazon and order a relay. Cost about 12.00 and fools the unit into thinking the park brake is set to activate all of the features. Just don't watch a movie going down the road!
Toyota owner since 98.
98 Limited 4wd, 99 SR5, 07 SR5 4Runner owner
02-05-2017, 10:38 PM
#30
I also like the removed running boards. Would like to get around to doing this on my rig.
Sent from my A0001 using Tapatalk
