Pre-cut platforms are NO LONGER AVAILABLE!! I will still sell the Adobe illustrator plans for them for $15 though
Below you will find all the information you need to choose the right one for you.
Please refer to the FAQ before posting any questions!
Due to the differences in engine bays between 1996-2000 and 2001-2002, there will be two main versions of the platforms, with many options for each!
Every platform is designed to work with all Blue Sea fuse blocks,
you do not need to specify which block you plan to use.
You can use any Blue Sea fuse block you wish: 5025, 5026, 5028, 5029, 5030, 5031, 5033, and 5034. All of the ones pictured are using the 12-circuit w/negatives (5026).
Ordering + Options
Base price = $35
Each kit will come with:
-The
unbent piece of acrylic
-All necessary installation hardware
-Installation Instructions
-Kits will
NOT include any of the electrical hardware or the fasteners needed to attach them.
TO ORDER: Please send me a PM in the following format, see below for details on the options:
Fuse platform order - your user name
Option 1: A or B
Option 2: Yes or no
Option 3: 1 or 2
Option 4: panel or surface
Your name
Your paypal address
Option #1: Version A or B
A= 1996-2000
B= 2001-2002
The 96-00 version here with the optional spaces for a relay and 2 surface mount breakers.
Every part is located very specifically due to tight under-hood space, minor hood insulation trimming may still be needed.
The 01-02 version is shown here in the optional fluorescent green with the optional relay, and 2 panel mount breakers.
The etched text is MUCH smaller on the production version you would recieve.
Option #2: Ignition relay (Yes/No)
Leave you room to add a relay?
A relay is basically an electronic switch that is activated by another circuit. The main circuit (fuse block) will then only be active when this other circuit is active. The most common method is to wire this relay to the vehicle ignition circuit so the fuse block is only active when the truck is on.
The relay meant for my design is this one:
E Support DC 12v 100amp SPST relay. $8.99 on Amazon as of this posting.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
For wiring help, see the below FAQ
Option #3: Number of Breakers (1 or 2)
Select two breakers if you also plan to do the BIG 3 Mod, otherwise select 1 breaker.
2 breakers on the 01-02 version is $5 extra due to it needing a support leg.
See below FAQ and wiring help to determine how many breakers you want.
Option #4: Panel mount or Surface mount breakers
Which Blue Sea 285-series breaker will you get?
Blue Sea 285-series breakers come in two styles, panel mount and surface mount.
*Please note that on 1996-2000 4Runners, surface mount breakers may require minor hood insulation trimming.
Option #5: Colors! (adds $10)
Standard platforms come in clear acrylic.
If you want a special color, that can be done for $10. Please allow 1-2 days extra lead time.
TO ORDER: Please send me a PM in the following format, see above for details on the options:
Option 1: A or B
Option 2: Yes or no
Option 3: 1 or 2
Your name
Your paypal address
