Fuel Tank Relocation (and new Rear Bumper design)
So my tank (the replacement, mind you, after the first one was damaged in shipping) came in today:
- sent it back and ordered another one. Third time's the charm?
WTH!?!?!?! Did Ace Ventura deliver that that thing or what!?!?!?!
I need to do this to my 4th gen, tired of beating up my gas tank skid that hangs down super low and I have a huge area under the hatch with the spare gone and my 1.5" BL.
The only problem is my 23 gallon tank is nice...
[MENTION=28464]eimkeith[/MENTION] What the hell?! Where are you ordering this from?
I just talked to my brother finally about getting the tank from his work. $150 with the sending unit and pump. I’m going to wait a little bit to order it since baby #2 will be here probably today and I won’t have time for at least a few weeks. Good to know I can at least get the parts I need easily.
What the hell?! I don't get notifications anymore when people tag me [emoji849]
Okay, all I meant by "splitting hairs" was just picking apart what you said.
I like lower ride height and no rake...Some folks like that raked stance and I'm not sure why. Maybe to keep from bottoming out easy? I don't mind being a hair lower in the rear when fully loaded with lots of weight.
I don't see how you could be "a hair lower when fully loaded with lots of weight", if you don't have any rake unloaded. I mean, I do, but you would have to have super high rate coils. I wouldn't mind being a hair lower when fully loaded with lots of weight either, but that would mean still having over an inch of rake when unloaded(with the Superflex I have). Which is about where I am at.
I know I'm being redundant, but I'd really like to get my hands on a set of 5th gen Superflex to see where they sit on our rigs. They even have a HD version, which might be a good option for the guys that want the load capability of the 861, without the height.
I'm glad [MENTION=67615]Dirtco[/MENTION] came through with his aux tank setup thread, as I hadn't considered cutting out the cargo crossmember. That'll give another inch of clearance for sure. But, that does mean high COG.
There are always trade-offs I suppose.
[MENTION=116470]Tyler James Inc[/MENTION] I guess that makes sense. I usually drive around with a pretty heavy tool box with spare parts, fluids, and also a high lift. So most of my weight is already accounted for during daily driving ride height. Which is still about an 1 to 1.5” higher in the rear with my old 8 wraps. So me fully loaded is an ice chest, couple chairs, and sleeping bags, water and extra clothes. The added extra weight is maybe another couple hundred pounds for a long trip. With the fuel tank moved to the rear, that should settle everything out for me. If I had .5” rake during daily driving I’d be fine.
Also how far along are you on your swap? Anything new besides the other picture you posted earlier?
I think I kind of interpreted "fully loaded with tons of weight" differently than you meant. I was picturing a setup like a picture of [MENTION=116387]Unner[/MENTION] I saw recently, where he had the back cram-packed, 3 bundles of firewood hanging off the spare, etc [emoji23]
No, no more progress on the swap yet. My buddy built a cage for the tank, and then made mounts to the frame from there. Seems like a great way to do it.
I'm trying not to give too much info on his. Not because I don't want to help, but because you and [MENTION=28464]eimkeith[/MENTION] both have great brains, and I'd like to see what we all come up with.
I think we need a group message/chat on this [emoji12][emoji848]❤️
finally got a few minutes to work on the fuel tank relocation; had to cut off the muffler and snapped off a hitch mount bolt in the frame (rusty truck), but I've made a hole for the new tank:
so a 1" BL is the way to go for tucking the tank (I'm working on a bracket design):
That’s looking good with it being tucked up that high. [emoji1303] I’m a little jealous but then again I also don’t have a body lift (frame drop)...
I like the idea of and the fine work everyone does on this relocation. Only thing is I remember something about Crown Vics and Pinto's. For me where I drive it wouldn't be a DD. :lookout::flame:
Its the factory position on many (even post Pinto!) vehicles... Keep it safe and don't put any protruding objects that can puncture the tank nearby and it'll be fine.
Said the chrysler engineers who made the exploder jeeps. They had to put a huge beefy hitch to compensate. But i agree it will probably be fine; if it not your daily driver then who cares!!
Sent from my SM-G930P using Tapatalk
Whats the benefit of doing this besides avoiding contact? I must have mis read it but OP said its the same size as a STOCK tank at 18gallons?
Nothing. In fact, more negative effects if you aren't worried about belly clearance. Okay, maybe more balanced than it being on the driver side, and being able to run a legit rear 4-link.
Belly clearance is a pretty big benefit to some. Being able to run a legit 4-link is also a pretty big benefit to some.
This tank relocation is NOT about extending run time per fill up.
