Originally Posted by Buckaroo
Other folks have said it....if your brake pedal travels too far but firms up, this is typically a rear brake adjustment issue. If the pedal is soft but pumps up, it is usually a hydraulic issue - air in the lines or bad MC.
Buckaroo
I’m at a loss on mine
I had the back brakes adjusted and they firmed up more, but the pedal is still soft and has some travel before the brakes engage. I replaced the MC and bled the brakes with the motive bleeder at 15 psi. I also engaged the ABS when it snowed hoping to get air out from there if it exists
Still don’t have a firm, responsive pedal
