IT LIVES!!!
Cranked it over twice and it fired right up as if it had never stopped running! It's so buttery smooth compared to my last engine, I'm really happy so far. Obviously, I will need to put a few k's on it before I'm in the clear but it's looking great so far on day one.
So happy for you, Jerod! It’s like you turned back the clock - OEM Toyota build quality, tolerances, etc. JDM is inherently a gamble but more often than not you get a winner. Enjoy it!
Both of us have more Japanese 4Runners than most people now! I don't know if you experienced this or not (I think you said a shop did the swap?) but the moment it fired up I felt like a weight had fallen off of me. All that hard work and patience paid off. It cost me about $1800 all said and done for the engine, fluids, tools, engine stands, etc. to do the swap so I'm pretty happy about that too.
I remember that feeling! I did the swap myself - will share the story here on T4R.org: could help others avoid the same situation that led to replacement of the engine and transmission. I still use the engine hoist here and there but the pair of engine stands sit unused. My 12 year old wants a 3rd Gen 4Runner when he’s 16 - depending on what we get for him another engine replacement might be on order. Hopefully the JDM 5VZ-FE engines keep coming over, for all of our sakes.
Did you bolt the SC on? Thinking you want to run it NA for a bit to make sure all is well. I have ~20K on my JDM so far.
Naw S/C was the first thing to go back on once the engine was in! I won't push the engine for a few weeks though to allow it to break in a little. It has a bypass valve so it doesn't build boost until you get on it. I'm addicted to the rattling noise at idle and the whine, can't live without it now!
Needed to perform some eye surgery this evening, the poor TYC headlight gave out on me. One of the clips that are spring loaded gave out and wouldn't go back together so it would point at the ground and wobble about. Tried to secure it but it didn't work.
15 minutes later, and had the new one in and with a few turns of the adjustment knobs, aimed and ready to go! I would complain about the quality and all that buuut... they are $40 on Rockauto.com so... yeah. Sure beats dealer prices!
I've got about 700 miles on the engine now, and ST and LT fuel trims have leveled out pretty good. However, my old tune has not. It's ok at WOT but partial boost it drops into the 10's when it should be more like 12.5 to 13.0! Going to try tuning it a bit this weekend if the rain ever lets up. For some reason it's only been raining on weekends here in NorCal.
Taken from the thread I started here:
Thinking About Upgrading Your Sound System? Do It! - Toyota 4Runner Forum - Largest 4Runner Forum
Here's my complete sound overhaul - on a modest budget. I just finished installing sound deadening on the front doors and new Infinity component speakers up front powered by a modest amp. I knew the stock speakers were pretty awful since I've swapped speakers in other cars before but this is the first time I've gone a more serious route. Here's what I've done:
Installed Alpine head unit for BT & USB - $99
Alpine CDE-143BT CD receiver at Crutchfield.com
Installed Alpine power pack, 45RMS x 4 (a bit higher since the Infinitys run at 3 ohms, not 4) - $100. Best part? NO EXTRA WIRING NEEDED!
Alpine KTP-445A Power Pack Compact upgrade amplifier for your Alpine receiver ? 45 watts RMS x 4 at Crutchfield.com
Installed 6 1/4 in. Infinity Reference X Components - $105
Reference 6500cx - Infinity US
Sound deadening on front doors as well as on the center console and transmission tunnel - $395 total spent in materials for the entire vehicle from RAAMaudio - Automotive sound deadening products Also, they have a GREAT how-to article for newbies like me, not every surface needs to be plastered with the stuff for great results. I ordered an additional amount, now up to $395. Wanted more foam and mat materials to do the entire cargo area since it's so noisy compared to the front end now.
6 1/4 in. Coax Infinity Reference X speakers on rear doors (current ones are completely blown out) - $70
Infinity Reference X REF-6502ix 6-3/4" 2-way car speakers — also fit 6-1/2" openings at Crutchfield.com
Sound deadening in the rear cargo area, it's noisy.
Powered Blaupunkt 10" subwoofer - $216
Blaupunkt Blue Magic XLb 250 A Single 10" subwoofer enclosure with 250-watt amp at Crutchfield.com
Wiring kit from Crutchfield, 10 gauge - $40 Don't get this one: http://www.crutchfield.com/p_142PA8BX/EFX-PA8BX-Wiring-Kit.html?tp=2919, the RCA's failed in a week. I'm so bummed. Get the Kicker or higher quality ones that have RCA's made with copper for more strength.
After doing the front end of the vehicle, it is a HUGE improvement in sound, at least to me. I still get a lot of road noise from the rear of the vehicle but the speakers sound awesome. I tested it along the way to hear improvements to see what was most effective:
  1. Adding the amp brought it to life. These Infinitys really shine with an amp, but I knew that already. Clear highs and good bass, almost feels like I have a small sub tucked away somewhere!
  2. The sound deadening quieted down the cabin and increased bass response but more importantly, took away all the rattles I had in the door panels.
  3. Just swapping the speakers did very little to improve sound, even though Infinitys are good quality. Would have been a waste of the speakers if I stopped there.
Now that I'm really going at it, an amp and sound deadening or some sort of insulating foam is a must. Those showed way more improvement than just swapping speakers.
Also, no more distortion at low frequencies that was hurting my ears :( Did I mention I did not have to do any wiring for the amp? That was the best part, it's literally plug and play. Only tricky part was where to mount it, I ended up putting it right below the head unit but far enough away that heat would not be an issue. I'm all for easy routes, and besides a new head unit plus a new amp for $200 is a complete steal. Crutchfield sells open packages for cheap, and Amazon and Ebay will have steals if you watch long enough.
I've put in about $900 to do the whole 4Runner, but it could be done for less if you're not so picky about sound. There are some decent Alpine or Pioneer speakers out there for much cheaper, I just love the sound of the Infinity Reference X line. Decent bass but the mids and highs just sound sooo good to me. Highly recommend going to Fry's or a car audio store to listen to speakers before you buy, they really do sound different when compared. If you guys want some photos I can take some of the next parts of the installs, such as my plan on how to fit 6 1/4 in the 5 1/4 openings on the rear doors and such. I was really cramped for time over the past week so I didn't have any time for photos of what I did up front but could take off the door panel if you really, really want me to. I've put in about 10 hours total so far with the install, it's slow going especially when I have to solder new wiring but not hard at all.
UPDATE: Just finished the deadening and wow, what a difference. The rear cargo really is the problem spot in our vehicles. There's still engine noise but there's nothing coming from the back of the 4Runner anymore. All the sounds are still there but reduced, if that makes sense. Also pretty much all high-frequency sounds are gone. I can hear my wife talk to me much, much better than before.
If you wanted to go one step further, do the front floor, that's the next spot that would need it. I'm not going to though, I'm happy with what I've got.
Anyway, hope this helps someone looking to plan their next sound upgrade on their 4Runner! Here's the photos for reference (I adjusted my crossover settings so had the door panel off this evening):
Tweeter:
That's right, I glued it, just like how the stock ones were. The ones I have are in a solid casing, there's no magnet to move like the woofers. The component set had three different mounts but there's not enough space to fit it behind the grill (the stock tweeter is very thin, probably why it sounds bad!). Gorilla Glue and a clamp and we're done! All you audiophiles are probably cringing right now :)
Here's a few more photos for kicks:
Crossover location inside the door above the support bar (not deflecting any sound waves and not blocking the window operation):
gamefreakgc-albums-interior-body+mods-picture35041-crossover-location-inside-door.jpg
New speaker on the old mount I did use the supplied mount provided in the kit for a more secure fit:
Finished product. Not pretty on the outside but it sounds awesome and nobody sees it anyway!
Also put foam on the inside of the door panel, took away a lot of rattles. I used twice as much foam as I did sound deadening:
More photos, updated 9/8
Routed the power wire for the amp through the firewall plug (poked a hole with a screwdriver)
gamefreakgc-albums-interior-body+mods-picture35479-power-wiring-through-hole-firewall.jpg
And then ran it under the trim to the back. Also ran my RCA's on the OTHER side to remove any risk of sound contamination.
Installed the volume control knob in the pocket under the head unit using Velcro. Great location and easy to remove if I ever need to. If you haven't bought a large supply of Velcro yet... it makes life so much easier.
Stripped the interior (which is a whole lot easier than it looks, took all of an hour) and added sound deadening. I ran out though so waiting on some more to come in.
Took out the plastic pocket and glued some carpet in there instead. Now my storage is 3x what it used to be! No more rattles either. Shout out to [MENTION=65101]BrianSD_42[/MENTION] for his photos that gave me the inspiration.
Bonus pic of the other side in progress.
All I have left to do is finish the floor of the cargo area and I'm DONE!
Post #2:
Ok, had some time last week to do the rear doors as well as some of the interior panels, I took a few photos that I hope will help some people. I will also show how I mounted 6 1/4 in speakers in the rear doors. It was a pain, but doable.
First, how I mounted the speakers in the rear doors. I took the existing plastic mount, trimmed it flat and traced it on 0.22" MDF board that I picked up at Home Depot. This thickness was perfect, not too thick but still rigid.
Then I cut out the opening by tracing the mounting bracket supplied by Infinity. I have to say, that bracket was super helpful since it had hole alignments that fit perfectly for a Toyota. I did have to trim off some very long screw mount holes, but nothing terrible. I ended up putting screws straight through the bracket, MDF and into the door panel in the stock holes, except for one. If this is not an option for you, you'll have to cut out a second "ring" for a mounting bracket and then either glue it to the MDF board or sink the mounting screws so they don't stick up, and then put in more screws to hold the speaker to the ring.
Wiring was simple, no crossover to deal with.
The harder part was trimming the door panel. This does cut into the inside of the pocket, but there's extra space in there so you don't notice it. Even with taking 2" off the side there's no chance of anything falling inside the door. If you take off the panel you'll see what I mean.
Also stuffed the center pillar behind the door with foam and coated over some of the holes in the metal. No more echoes. BE CAREFUL WITH THE CLIPS! These metal ones tend to bend and break, one snapped off and was lost in the pillar. No need to detach anything above the removable panel, that's where I went wrong.
My Infinity's sound AWESOME now that they are tuned a bit to my liking. They actually have really good mid-bass now that the doors are done and essentially act as custom enclosures. With the 10" sub it sounds fantastic. Went with this one since it's easy to wire, just run power, ground and RCA's. Amp and sub come pre-loaded in the enclosure. No remote wire needed!
I put the exact same speaker setup in my 99. Love it.
Had some time in the past week to start fiddling with my tune a bit. So far, this new engine is much easier to work with than my last one. I think it might be due to having much better compression and not passing fuel into the exhaust as much. I need a few days to test it all out but I think I've got a much better partial throttle fuel map!
I still need to re-tune the WOT area but that shouldn't be too hard. Mash pedal to floor, turn on logging software, read log, adjust tune, repeat. AFR's between 11.8 and 12.0 and call it a day. It's also been raining here pretty much like clockwork every weekend and need some dry roads.
Ok, here's my 80% done new tune! Notice how I added a value in every cell, this helped the piggyback play nicer with the ECU. Also figured out how to keep my O2 skew active for more than a month or so. The last tune the ECU would de-tune it slowly.
I still have the top 3 cells in the fuel table to test again but weather has been poor or been busy to do it right. I don't expect major changes though.
Been researching and reading up on cfm and airflow, both for the intake and the exhaust. There's a service I've eyed in the past at Maxbore.com throttle body boring service and repair who does throttle body boring. His service would increase flow through the throttle body by 12%.
I can't seem to hammer down an exact number, but at 11 PSI my engine needs roughly 600-650 cfm of flow and there's restrictions along the entire way. Throttle body, air box, air filter, etc. Probably going to rethink my entire intake but I need to be able to swap it out to pass the visual inspection.
Then it's time to put a real cat-back exhaust. Going to do 2 3/4" mandrel piping with another Borla muffler (I like the one I have but it's too small). Now I just need to find some money...
Interesting find today. I've been having a hard time nailing down some weird O2 sensor issues and some tuning quirks I can't seem to clear up. My downstream O2 sensor was original and at 223k miles it was time for a new one.
I've always been told the rear O2 is only a dummy sensor and does not affect fuel trims. I tuned my 4Runner based on this assumption. Well, it's wrong!
I replaced my sensor overnight and did not touch the vehicle until this morning. I have a wideband with a gauge so I can read my AFR's in closed loop when the engine is cold. Idling in my garage it's a solid 11.8-12.0 AFR's (always ran rich like that after the injector swap). When I shift into reverse, it leans out a little to 12.5. Today however, after the rear oxygen sensor swap it started up and idled at 13.5 AFR's and in gear was 13.8! That was definitive that somehow, the rear oxygen sensor dictates open loop fueling. Now once I drove down the street, in about 10 seconds the front sensor was heated up so it took over and we were back to 14.7 as usual.
Now why the rear affects the open loop fuel trims I'm not sure. It could be the old sensor was fouled and not reading correctly so dumping on fuel, or it could have been old wiring and electronics that skewed the voltage reading, I'm not sure. I hope to do some WOT runs soon and we'll see if the top end leaned out at all at open loop as well. I'm thinking it might have since I have to pull a ton of fuel.
That is very interesting. I've always believed that the rear O2 was simply to monitor the CAT and make sure that it is working by reading reduced emissions compared to the front O2 sensor. I will be interested to find out what you learn and I will begin to look for an explanation as well.
Had a chance on my commute home in rush hour traffic to pull a good WOT run. My open loop fueling did not change at WOT, only at startup and idle with the rear sensor change. So I guess it has very little affect on fuel trims.
I'm bringing back the HP counter! Guess what that means... yup I'm prepping for another dyno run sometime this year. If you remember, I ran into some issues on my last dyno run. I couldn't get it past 4800 RPM's in 3rd gear due to the speed limiter so couldn't get a good HP rating, among other things. However, it did make 256 lbs of torque on a Mustang dyno, so that's roughly 250 HP. That puts me at:
Running Total:
+103 HP
I just ordered a new filter but decided to up my game. The Toyota paper filters have been fine as they trap debris very well but I don't offroad much and live in city so decided to live life on the edge. Lots of opinions out there but went with an oiled aFe Power Pro 5R filter (currently 20% off!):
Magnum FLOW Pro 5R Air Filter | aFe POWER Their entire site is 20% off, worth checking for any car! They make good stuff and dyno test all of their kits.
I'm expecting an increase in flow and my intake is not ideal, it's not flowing enough air for what the engine needs. It's also not flowing enough out of the exhaust but that's for another day. I plan on using the Torque app and do an average of 3 runs with the stock air filter with the HP calculator then do 3 more with the new filter, then 3 more with no filter. We'll see what happens!
So, I had some time to run a few times down the road and get some power readings with the two filters. Here's the chart and I'll discuss the data below:
gamefreakgc-albums-engine-performance-mods-picture55048-afe-filter-dyno-runs-vs-paper-filter.jpg
Orange line is the aFe 5R Power oiled filter, blue is my stock paper filter. Pretty conclusive by the chart this thing flows better for my engine. Now, before you ditch your paper filter on your N/A 4Runner know that my engine is heavily modified and has a higher cfm flow than stock.
That being said, I'm very pleased with how it performs. Peak gain might only be +3 HP and +4 lbs tq but max gain is +9 HP and +9 lbs tq at 4500 RPM! Now this is just preliminary data based off my AEC FIC 6 logs (using Virtual Dyno) but it's shown to be pretty darn accurate. I'm going to give this filter a straight +6 HP, the power is there. Confirms also that my intake it still too restrictive.
A few other things I learned today is that heat soak happens on the third run. You'll notice the top end REALLY drops off once you go back 5000 RPM's. That's what happened on the dyno last year too, heat is a real limiting factor on this engine. I might do another run soon when the engine is cooler for some better comparisons. I took at total of 6 runs, that was too many without allowing it to cool down.
Also, I learned that the AEM FIC reads the AFR +0.3 higher. I will need to re-tune my engine soon to correct that.
HP Gain:
+6 HP
Running Total:
+109 HP
Guess who fouled another O2 sensor? I wonder if there's bulk pricing...
I'm going to try and throw in A/F sensor from a 99 and see what happens. Worst case I just return it.
I've been sick for over 40 days straight... but finally on the mend! In between storms I had a chance to tweak my tune a bit and it made a BIG difference! Upon following some advice, I leaned out my tune into the low 12's, so around 12.0-12.2 and wow, did that wake up my engine! I saw roughly +18 HP and +18 TQ from my Virtual Dyno program!
gamefreakgc-albums-engine-performance-mods-picture55365-afe-filter-leaner-afr-12-0-12-2-a.jpg
I need to do a few more runs to confirm this but so far I'm seeing more top end power leaning out the AFR's a little with meth injection. I was previously in the 11.6-11.8 range.
^^ Yes this is expected. Meth setups seem to like a 12.0 AFR.
The challenge I've had with mine is COT (cat over temp). On some runs my AFRs will be 11.9 - 12.3 and on other it'll be 10.9 - 11.1. NO changes to the vehicle.
My assumption is it's COT kicking in and dumping fuel to cool things down. Too bad we can't shut if off that I know of. We turned it off in the Hellcat.
I've never heard of that before. I don't think my slightly archaic 98 ECU has the ability to read exhaust temps, I'm guessing that would be data taken from the upstream or downstream O2 sensor? We don't have an EGT sensor which is a bit of a bummer since that data would be awesome for tuning.
I would have thought water injection would keep that under control though, since the water doesn't burn off it just evaporates. Could it also be possible you've got some belt slippage and when it makes more boost it's leaner, and if the belt slips you're running rich?
