Old 04-26-2018, 03:42 AM #1
bwv7131's Avatar
bwv7131 bwv7131 is offline
bwv7131 is on a distinguished road
bwv7131's Avatar
power locks
I'm having issues with my power locks for my 1998 T4R SR5 5sp. I can only unlock/lock driver or passenger door with key in outside key hole (won't lock/unlock all locks if turned either side twice). Power locks inside don't work and no noise made from locks when I try the power lock button. I do not have a key fob.
I tried replacing the 30A fuse under the steering wheel, the driver's side actuator and the master switch with no luck.
Am I looking at a wiring issue here?
bwv7131 is offline   Reply With QuoteReply With Quote
Old 04-26-2018, 06:47 AM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
It’s most likely the drivers side fuse block. The fuse you replaced is in the drivers side block. It has relays in it that are a known issue on these trucks and a bunch of other Toyota models. It’s not a cheap part and it’s a pain to replace but it’s not hard to do.
82730-35260 My 2000 used this part.
Old 04-26-2018, 08:29 AM #3
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Unfortunately the highest probability is the Body ECU. However the possibility of a wiring failure, especially between the driver's door and the body, is also a valid idea to follow. If you have some jumper wires and a multimeter the body ECU can be tested fairly easily. But it does involve some disassembly and patience. If you search here on this forum it is well documented, otherwise it is a lot of back and forth to explain it.
I should put together a tutorial, right after that one thing, and those other things.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Power locks mrplumbing80420 New Members 5 01-17-2016 02:08 AM
Power windows / power door locks inop jimlaw3 Classic T4Rs 3 12-24-2015 04:00 PM
inconsistent power to power locks 99 4runner Sierra Runner 3rd gen T4Rs 1 05-20-2012 02:59 AM
Rear power window/ Power locks Brian Keeler 3rd gen T4Rs 2 06-01-2010 02:21 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
