BrianSD_42
I figured this deserves its own thread.
Actually there is little variation on what is recommended by Steve at Sonoran Steel for the 1.2 lift kit using OEM Toyota Tundra Coils front and LC coils and shocks rear. He is VERY SPECIFIC that only certain years and exact models will work and won't ride like crap. This setup is hardly cheap but it is certainly a GREAT quality setup and ride for your well earned cash. I am still running the rear setup, going on near 10 years now. And for the front well I upgraded to King but not really out of necessity, more out of a tax return that was a bit flush.
I'll continue to suggest the OEM/Toyota Tundra+LC setup. See Sonoran Steel’s website Build It Yourself section, they have the part #s posted. I’ve run this and it has worked out great for years and years on trails all over the West. The parts need to be exactly these, not any other close part #s. Per Steve, substitutes likely will render poorer results.
I recommend you check out the deal Steve is offering of $500 for the starter kit including instructions and phone support (for customers only).
So $700 + $240 = $940 (no tax and free shipping!). Plus $500 to Sonoran Steel if you want the quick setup kit linked and that equals ~ $1,440 out the door for a proper correct real Toyota parts LC+Tundra badass lift kit. You would still need to assemble the front strut and coil together but you aren't experienced you can pay a local shop 1 hours labor, lets say $100 to assemble it for you. That brings you up to $1,540.
BTW, Steve's $500 DIY kit includes:
--> Sonoransteel.com 1996-2002 - System 1.2 You Build It
:bat:
Also, seems like there is a lot of variations to [the Tundra + LC kits] that people are running and I feel like I won't know what to buy or where to buy it at.
FRONT - These EXACT PARTS:
* Front TRD Coils: 48131-AF090 & 48131-AF100 (1 of each specific part #) [$191 each]
* Front Bilstein 5100: 24-261425 (Qnty 2) [$120 each at AutoAnything] --> https://www.autoanything.com/suspension-systems/77A5660A6319055.aspx
REAR - These EXACT PARTS:
Rear Land Cruiser Coils: 48131-6A570 (2)
Rear Toyota Tokico: 48531-69417 (2)
Kit Includes:
1 of 1” Tapered Diff Drop Kit
2 of Custom Polyurethane Top Plate Seats, Mold Number: M20190
2 of Rear shock mounting kits for long travel Bilstein 5100 or Tokico Land Cruiser shocks
1 of Adjustable Trac/PanHard Bar, corrects alignment and more rear articulation over a bracket
2 of Custom rear bump stops/adapters to adjust to either brand long travel rear shocks
2 of Rear sway bar brackets, gives the rear axle more articulation with sway bar connected
1 of 6mm Allen Zerk Plug, prevents damage to rear drive shaft and gas tank skid plate, under long travel conditions.
1 of 3.5” longer rear brake line, Braided/Stainless, for long travel shocks (2001-2002 add $35.00 for second line)
1 of Parking Brake Bracket for long travel shocks
:bat:
