Ok, I wanted to rule out a couple of the obvious points first:
First, you live in SF, and if you're driving up and down those hilly streets, your MPG will suffer. Plus, judging by your sound system, I'm guessing you don't have the most conservative gas peddle (
). Also, how is the traffic? A lot of idle time? With going up hills, stomping on the gas peddle and hitting a lot of traffic, I can see 8-9mpg. Lastly, how are you calculating your MPG?
I don't think you need to change out your O2 sensor if you're at 80k, unless you're getting a CEL.
