LED lighting
sweet i been wanting to do this for while to, just had to use my cash for some other stuff so hopefully i'll have the funds for this at the end of next month.
so it probably took you around 2 hours to do the whole thing?
at most it took two hours, i wasnt timing it but i would say it was less. All the bulbs with shipping was only around 45$ so it was fairly cheap too!
so anyone have details on how to take off dash display to change out the 3 194's? also, how to get the heat/radio console off? i have a 97'.
thanks
thegreenmonster said:
the lights in the dash on 99+ 4runners are NOT #194"s they are #24's. unfortunately i figured this out after i ordered my lights
Oh thanks for telling me! I would have ordered the wrong ones for my 02.
no problem
#74's i've heard will work, but they are a little loose
#24 is the correct bulb
You are incorrect, on the 2002 4Runner's there are no #24 bulbs, The HVAC controls use two Type A Neo-Wedge bulbs, and three Type B Neo wedge bulbs. You can get them from www.autolumination.com And the guage lighting consist of three #74 bulbs.
Sloan said:
the map light, dome light, and cargo area light are all DE3175
they sell about 10 bucks a bulb on ebay
The map lights are Ba9's. At least they are on the 2002 models.
Yeah it's very confusing, I don't know why they wouldn't have used the same bulbs every year. I wish they would've used 194's for the guage lighting, that'd be so much better than the 74's. And the Neo-wedge LED's blow a big one for the HVAC controls, the hot spots are so bad, it looks horrible.....
Well I have an 02 and now I am totally confused LOL! When I actually do it I guess I will just have to pull the bulbs out on my truck then order the bulbs.
If you have a 2002 I can tell you every thing you'll need to order. Just tell me what all you want to change and I'll tell you what you need.
yeah
i was going to recommend doing that because then you will know exactly what you need. and taking the cluster out isn't hard at all. 15 mins. tops
I do have an 02, and I will probably change out all of it. Can you change the clock illumination too?
