Old 01-31-2009, 08:24 PM #1
1800AskMatt's Avatar
1800AskMatt 1800AskMatt is offline
1800AskMatt is an unknown quantity at this point
Question HELP!!!Rear end sway at Highway Speeds
Does anyone have issues running 70-75 mph on the interstate and have rear end sway like a crosswind or passing a big truck?
I have checked the sway-bar and end links, shocks, ALL 4point connections to the rear end housing and tire pressure.
Only thing that keeps coming to mind that I have done to the truck lately is 1.5" wheel spacers.
I check the torque again and it is right on the money.
I even removed them and ran a few days without them and have the same problem.
Any help or suggestions will be appreciated.
1800AskMatt is offline   Reply With QuoteReply With Quote
Old 01-31-2009, 08:35 PM #2
p nut p nut is offline
p nut is on a distinguished road
Have you had an alignment done? Maybe uneven tire wear?
p nut is offline   Reply With QuoteReply With Quote
Old 01-31-2009, 08:36 PM #3
Matthew Starr's Avatar
Matthew Starr Matthew Starr is offline
Banned
Matthew Starr is on a distinguished road
Banned
Re: HELP!!!Rear end sway at Highway Speeds
haha i love your screen name. I had that problem and it ended up be my new tires. I dont know how long ago you replaced you tires and if you've done 70mph + with em until now, but that is my only suggestion. Excuse my lack of knowledge with tires but my old tires (goodyear silent armor) had a stronger side-wall for against moving horizantally but less against moving vertically. then i got goodyear wrangler td's and it was the opposite cause they're more of a towing and offroading tire. The other thing i just thought of is that those wheel spacers (in my oppinion you should return and get wheels with an off-set) could be defective and be out off balance.
Matthew Starr is offline   Reply With QuoteReply With Quote
Old 01-31-2009, 08:39 PM #4
Tires are still in great shape and have the right pressure. This was not a problem one month ago with same tires. Michelens
'01 Toyota 4Runner SR5
4x2, 3.4 V6, Deck Mod, DRL Mod, Wheel Spacers, Nerf Bars, 3" Fat Bob's Garage Lift Kit, GPS, XM Radio, Early Model Rollbar, K&N Air Filter and other little things. More to come......
Old 02-01-2009, 03:51 AM #5
J-money$$$'s Avatar
J-money$$$ J-money$$$ is offline
J-money$$$ is on a distinguished road
J-money$$$'s Avatar
I experianced this once awhile ago, but I was going 107 mph. Which is pretty dumb on its own in the runner. The rear end started getting light and almost drifting. I figured it was from my cr**py dunlop tires. I know this dosent help much but I just remeber the rear end doing werid things
check out my build thread My Build
J-money$$$ is offline   Reply With QuoteReply With Quote
Old 02-02-2009, 11:47 AM #6
410toy 410toy is offline
410toy is an unknown quantity at this point
I had a similar problem on my 1998 4x4 pathfinder. It turns out that I destroyed my trailing arms. I had them replaced and problem went away. I know 4runners are different vehicle but something to look into. You might just need to replace the bushings.
2000 4Runner SR5 V6 4X4 auto
TRD ceramic coated headers, DRL lights turned off !!, Royal purple fluids, Toyota Tranny cooler,silver star headlights, PIAA HID corner lights, Hella fog lights, LED Tail lights, PP1 springs Bilstein shocks, Addco sway bars F/R, EBC Rotors & Pads, Gloss black calipers, Russell SS brake lines, urethane steering bushings, Nitto Terra Grapplers on Black Rock Viper wheels, Air elbow mod, Deck plate mod, Rear diff breather mod, Inline weather guards****** Friend don't let friends drive stock ******
410toy is offline   Reply With QuoteReply With Quote
Old 02-02-2009, 12:01 PM #7
Ron Helmuth's Avatar
Ron Helmuth Ron Helmuth is offline
Real Name: Uhhh this is my real name
Ron Helmuth is on a distinguished road
Sway bar twisted?
Could your rear sway bar be twisted or otherwise no longer stock?
just a guess....
06 4th gen V8 4WD of course...
08 Honda Ridgeline RT
05 Scion xB-the toaster-daily driver
my Yota Fanatic photos are on Facebook- here is link:
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline   Reply With QuoteReply With Quote
Old 02-02-2009, 01:49 PM #8
00Spork's Avatar
00Spork 00Spork is offline
Real Name: N3ZZAR
00Spork is on a distinguished road
00Spork's Avatar
Real Name: N3ZZAR
I would take a look at your panhard bar on the rear axle, I was getting wierd handling characteristics(i felt like wind was blowing me, even though there wasnt any) and my panhard bar had worked itself loose somehow. Just check to make sure it doesnt have any play in it, and if it does, put some washers between it and the mounting bracket.
00Spork is offline   Reply With QuoteReply With Quote
Old 02-02-2009, 05:11 PM #9
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
The panhard bar is what gives the rear axle lateral stability and strength.
techno is offline   Reply With QuoteReply With Quote
Old 02-02-2009, 05:17 PM #10
KellyJ's Avatar
KellyJ KellyJ is offline
KellyJ is on a distinguished road
KellyJ's Avatar
I have had the exact same sensation when driving my car lately at around the same speeds. Is there a way to tighten it up yourself if it is in fact loose?
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
KellyJ is offline   Reply With QuoteReply With Quote
Old 02-02-2009, 09:09 PM #11
I was under the truck and had someone shake and push the truck and dont see any movement at the sway bar end links, shocks, 4 link on rear end and pan hard rod.
Confusing
Old 02-07-2009, 12:30 AM #12
anyone with a good visual to help us out?
maybe someone has a good photo of the back end suspension pieces they would care to share?
Personally I do not know what the panhard bar would look like nor the trailing arms discussed above...
Would shaking the vehicle exert enough force to exhibit the symptoms of high speed instability?
Bushings are involved in the panhard bar right? And the rear sway bar?
I am learning all about the front end suspension and steering and tie rod inners.....just enough to be dangerous of course. he heee
Old 02-08-2009, 07:43 PM #13
Re: anyone with a good visual to help us out?
[QUOTE]Originally posted by Ron Helmuth
[B]maybe someone has a good photo of the back end suspension pieces they would care to share?
Old 02-08-2009, 08:26 PM #14
RunnerUp's Avatar
RunnerUp RunnerUp is offline
RunnerUp is on a distinguished road
RunnerUp's Avatar
check your lower links, my bushings had worn out and caused highspeed instability. you gotta get in there and look though, potentially even remove them to check the bushings.
you can not just buy the bushings though, you have to buy whole new arms.
'02 4Runner Lifted/Locked/Armored
'07 4Runner V8 Sport Edition 4WD
RunnerUp is offline   Reply With QuoteReply With Quote
Old 02-08-2009, 09:01 PM #15
Really, buy new ones?
I got in there with a prybar and nothing really had any slack
Steering Wheel Vibration at Highway Speed...revisited Thai Problems & Warranty Issues 74 12-18-2014 04:42 PM
hard shaking/vibration at highway speeds mx52nr 3rd gen T4Rs 10 11-05-2007 07:48 PM
4th Gen whistling/humming at highway speeds punkdork Problems & Warranty Issues 0 05-11-2007 03:50 PM
Noise in 4X4 at highway speeds mtnc Problems & Warranty Issues 3 09-27-2006 11:47 AM
Vibration in steering wheel at high speeds 20054runnerfan Problems & Warranty Issues 3 05-09-2006 06:37 PM
