10-10-2009, 10:36 AM
Emergency Brake Light appears randomly
Hello,
Have an issue with the Emergency brake light… it will turn on intermittently for a few seconds as I drive around town but the emergency brake is not engaged. I’ve noticed it turns on only when I make turns or speed up / slow down quickly but it’s not guaranteed to happen everytime… does anyone know what the cause is?
Thanks. Really appreciate you taking your time and sharing your expertise.
10-10-2009, 11:16 AM
the level float switch in the master cylinder can make that happen. Have you checked your brake fluid levels? Reason I say this is because it used to happen in my prelude and that was the solution.
10-13-2009, 12:35 PM
x2. Check your master cylinder. Fluid is probably low.
'00 4Runner SR5 - desert dune
--3.4L V6, 5 spd, e-locker, build in progress... --
10-13-2009, 06:59 PM
Real Name: Bryan
Real Name: Bryan
Your fluid is low. That's why on hard stops and acceleration and turns the fluid sloshes(is that a word?) around in the resevoir and makes the sending unit think there's no fluid in there.
Millennium Silver 2001 4Runner SportR5lander
Photo Timeline - Solid Axle Club
All-Pro, Fox, Eibach, OME, Goodyear, Trail Gear, Yukon, Solo Fabworks, Marlin, TJM, Smittybilt, Front Range Offroad, Inchworm, Addco, Savage Offroad, B&M, Borla, Pioneer, Cobra
Northeast 4Runner Owners Association
10-14-2009, 04:30 PM
mine does the same thing but its not the fluid level. i can disconnect the sensor on the master cylinder and it still does it. replaced the parking brake switch also to no avail. had two techs tell me its probably a problem in the instrument cluster.
10-15-2009, 12:43 AM
Real Name: Bryan
Real Name: Bryan
get a third opinion
10-15-2009, 04:03 PM
Both my 2nd and 3rd gen's did this due to the brake fluid level. It didn't even have to be noticeably low. Just a teaspoon to bring it right up to the line was all I needed to get my light to turn off.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
10-15-2009, 04:22 PM
It could also be your wheel cylinders/calipers. If they need to be bled, then it is possible for your brake light to come on. When I swapped a new rear axle into my jeep, I installed the calipers on the wrong sides which meant that the bleeders were on the bottom and kept sucking in air and triggered my brake light.
10-19-2009, 07:17 AM
I had a similar problem in my '99 Tacoma. Added some fluid, but it did not solve the problem. Finally did brakes all around (it needed them badly!) and no more light. Probably something to do with the very thin pads, calipers and/or needing to be bled down.
01-11-2010, 11:00 PM
My brake light was on also. It would occasionally go off but mostly it was on. I checked the fluid and it was about an 1/8 inch above the minimum level. I added fluid up to just below the max level and the brake light has totally gone out now. Problem solved...
01-11-2010, 11:25 PM
Well, well sounds like I just discovered the solution to my problem.
01-11-2010, 11:39 PM
I seem to have this problem too... always saw the light out of the corner of my eye when accelerating away from lights. I'll try filling the fluid tomorrow and see what that does.
01-12-2010, 12:42 AM
Filled it up, went off instantly. Poor 4Runner I've been neglecting you, but I'm making you all better now.
01-12-2010, 06:46 PM
Mine went away too.
12-17-2013, 10:55 PM
Real Name: Salman
Real Name: Salman
I am getting same problem mentioned by previous posts. Thanks to these old post, I think I got solution. My issue is, I don't know what kind of break fluid was used by previous owner. What kind/brand of break fluid should I buy to top up the master cylinder?
Thanks.
2000 SR5 Burple - Expedition Build | Front bumper ARB with Superwinch| Sliders | Tepui RTT | Wilco solo Tire carrier | Cargo Box with Arb fridge slider
2020 | HONDA | CIVIC | Molten Lava Pearl | LX | 300 Miles | DD |
8 Seater minivan but with V8 | 2003 | Toyota Sequoia SR5 4WD | Guest hauler|
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
