255 85 16s, 1 inch body and 3 inch suspension
1bad4r
i would like to see if anyone has this setup on a 3rd gen 4runner i have 285s 3 inch spacer lift and i am upgrading to 255s soon and am trying to decide if i want to add the body lift or not..so if anyone has any pics please post them :biggrin2:
Just put 3" front strut spacers on my 99 Limited (millenium silver) and FJ80 rear coil springs along with Nitto Terra Grapplers 285 75 16 and with a bit of a rub I'm adding some 1" wheel spacers later this week. This is my 4th 3rd G Runner, but 1st I've added anything too. It looks sweet. Still debating removing the running boards. they provide some much protection in our harsh salty winters. Not considering any body lift though. Seems like too much and I've never been much for those lifts showing all the body frame. Tried to load a pic but I can't figure this mess out.
i already have the same setup as you do...i am trying to see pics of trucks with 255 85 16s and a body lift or even some without
Those are some pretty skinny tires!! I know I saw someone with those tires on before..I just cant remember where. I'll try to search for the pics.
yea they are supposed to be a lot better since we have problems rubbing on the uca and they are taller than 285s also
I love hearing a 10" tire being called skinny.. a 265 is a whole .50" wider and then comparable 33" equiv(285) is 1.25 wider and considered fat... I would like pictures and to see as when my current set wears out I think I might go with this "Pizza Cutter" size.
1bad4r I don't think there are any 4runners with those tires. I have searched and only sikhiluxsurf had them or still has them in his truck, not to sure. My main concern is longevity and also road manners. I have talked to pikeman about this and for my driving maybe at best 20% off-road and 80% pave road this tire might not be the right one for me. But who knows it is to soon and I am still shopping around for tires 255/85/16 might still be a possibility?
its sounds like we are in the same situation exactly let me know if you find out any more info thanks
No problem will let you know if I get them. I drive about 12k a year and will hate to replace them if I only get 30k or less of of them.
today was a big day for me...
i already had the lift, toytec 3inch spacers with landcruiser fj80 coils in the rear...
but i got the km2 255's!!
so far im in love. they are freaking sick, fit my runner perfect SR5 with the flares taken off, no rubbing up front but i do in the rear, i rub on the mud flaps so im going to trim the bumper to fix this, but this was at full flex, not your flex that someone with 35's stuffed would even attempt. In a huge ditch with the locker on, and also on a flex ramp at a local 4x4 shop. i still dont belive those guys claiming they dont rub with those 35's i could see myself rubbing like crazy with the 285's! these tires fit perfectly in the wheel wells at full flex, i extended my bump stops with 2.5in square tube with holes drilled in it. worked beautifully.
im going wheeling tomorrow morning and will get some better pictures.
don't want to hijack this thread......
but a question. where is the best place to buy these fj80 springs and front spacers? how does it affect the ride? replace the shocks when you do it? i'm very new to 4runners and want to learn all i can. thanks
i got mine from my buddies fj80, and you will need new rear shocks, i just replaced mine, but had the stock ones on for a few months it was a rough ride because they were maxed out sitting on level ground. and the spacers off of toyteclifts.com
