My experience with P0301; Resolved.
trd_4runnin
I recently got a flashing CEL and the code P0301 on a road trip on the way home from Detroit. After finding out the code was for Cylinder 1 Misfire, I had a really hard time finding information and others with experience with this code. Found many threads about it, and how it had the owner stumped but not too many actual results. Hopefully this will help someone else in the future.
As stated previously, I got a code P0301 on the way home from a small road trip accompanied by a flashing CEL. It would flash and then go off for a while, or flash and then stay on for a while. I also noticed a bad hesitation during acceleration that seamed to get much better after 2,000 RPM, but not go away. Once back in town I had Advance Auto Parts pull the code and it was Cylinder 1 Misfire.
My first step was to replace the plugs and wires. They needed done anyways, so this seemed like a logical place to start. Unfortunately plugs and wires did not fix the problem. My initial thinking after this was that it was not a coil pack. I figured since each of the three coil packs fired 2 cylinders, the coil pack going bad would cause two misfires rather than one. I'm still not sure if this is the correct thinking or not, but I decided to rule it out officially. I removed the coil pack from cylinder number 1 and switched it with cylinder number 5 coil pack. Then headed to AAP again and had the code pulled. Still a cylinder 1 misfire. Coil pack ruled out.
Next step was to test the fuel injector. I bought a digital multi-meter from Harbor Freight on sale for $1.99. I was unsure how to test the injector, so after a google search I came across a couple of YouTube videos showing exactly how. If you never have looked up these type of videos on youtube before, they can be very helpful. I tested the resistance on the cylinder 1 fuel injector and the multi-meter wouldn't read anything. In general, injectors should be between 11 and 18 ohms, with more specific parameters per model. I also tested injector 3, which read 15.3; and injector 5, which read 14.8. This was all the information I needed. I called Toyota and ordered the injector. Changing the injectors on the passenger side of the engine is not a difficult job if you know your way around the engine bay decently enough. The drivers side is much more difficult and involves removal of the intake manifold.
For the 3 injectors on the passenger side I first had to remove the intake tube between the throttle body and MAF sensor. After this I had to remove the throttle body. If you have never done this, you need to be patient as it is somewhat involved. There are 3 cables on the front that need to be removed, 2 coolant lines, and a vacuum line from the IAC valve (located on the bottom of the TB), a clip for the IAC, clip for the TPS, and then 2 nuts and 2 bolts and you can remove the TB. After removal of the throttle body you have all the access you need to the fuel rail and injectors. There are 2 17mm banjo bolts on both sides of the fuel rail. You can remove these, and then 2 12mm bolts holding the actual fuel rail on. It may take some jiggling but you can then pull the fuel rail up and change the bad injector.
NOTE: EVEN ON THE INJECTORS THAT ARE NOT BAD, YOU NEED TO REPLACE THE O-RINGS ON THE TOP AND BOTTOM. THEY WILL LEAK!
Once the bad fuel injector has been replaced you can put everything back together the way you took it apart (it is also recommended that you change the TB gasket). Start the vehicle and check for leaks on all the injectors. I would also recommend checking the injectors again a couple times over the next day or so to make sure no leaks develop as the engine heats up and pressure builds.
Again, hopefully this helps someone at some point. Sorry there are no pictures but I didn't even think to take any during the process. Feel free to ask any questions and I'll answer them as best I can. Thanks!
Great write-up. Gonna help a lot of people. I love to see these contributions. Much better than how I installed led's into my glove box.:hatsoff:
oh, just want to add a little tid-bit of info...
If the CEL flashes, it's best to pull over and shut down the engine as soon as safely possible. If it is solid, that means the computer recognized an issue, but if it flashes, that's bad news, and to continue to drive/run the engine can result in engine damage.
This is true and unfortunately I didn't find this out until after I got back from Detroit. A flashing CEL ususally means a misfire is in progress. Obviously starving a cylinder of fuel is not a good thing so you definitely do not want to drive around like this.
Thanks LINY.
Thanks for the writeup. Can you tell me if the misfire you experienced was intermittent? I've got an intermittent misfire and getting P0301 codes, and after replacing the plug and ruling out the coil as you did, the injector seems the next step. Sometimes I can get as much as 50 miles with no misfire, then it returns. I've got a TRD supercharger, and feeling a little reluctant to pull it off to replace the injector, but I've got no confidence in my dealer's shop at this point.
Thanks for the info trd_4runnin. Can you post the links to the YouTube instructional vids on testing the injectors? thanks.
Mine was not intermittent. Sometimes it ran better than others but never really ran good. Did you check the wires too? If it's not the plug, wire, or coil pack then I would say it is probably a fuel injector.
Here are the two that helped me the most...
YouTube - Checking Fuel Injector Coil Resistance
YouTube - HOW TO OHM CHECK A FUEL INJECTOR
They obviously aren't on 4Runners but they get the point across. Getting to injectors 1,3, and 5 is pretty simple. Injectors 2,4, and 6 would involve removal of the intake manifold.
Good info and great write up. :hatsoff: The flashing CEL means damage is occurring to the catalytic converter from excess fuel being dumped in so hopefully you don't have any issues with that. Fuel injector failure is pretty rare though, right? Glad you could do it yourself since a shop would have raped you
Your info was great, my P0301 and intermittent miss did indeed turn out to be the #1 fuel injector. That is the only one I can actually get to the contacts on without removing anything and the resistance was around 1K. Another neat trick confirmed it, which I got out of Chilton's. They say listen with a mechanic's stethoscope. I've had a cheap one for years that never proved useful for anything until today. I put the probe on #3 or #5 injectors with the engine running and got a real nice tick-tick-tick. All I got from #1 was rrrrrrrr. I'm sure a thumb over the end of a long screwdriver would work as well as the stethoscope. Now the question is what to buy? I've found everything from rebuilt Python injectors for $20 up to factory list at $180.
If you can afford going with OEM Toyota I always recommend it. Check trdparts4u.com. They offer brand new OEM parts at a discounted rate.
Yeah I have had no other issues since then with anything, but my cat is going to need replaced pretty soon anyways. It smells pretty rough behind the truck. I would say injector failure is somewhat rare. I never really heard of anyone having to replace theirs until I had this code and started scouring the web for info. I'm hoping its my last one.
I just had a similar issue yesterday ironically while I was driving over to the Toyota dealership for an oil change. On the way my CEL started flashing and then went solid about 10 seconds later. The engine sounded louder and different and letting go of the accelerator from a stop would make the car jerk badly but after accelerating it would go away. The dealership said it was a cylinder #2 misfire. They said they couldn't get it to happen again and I've been fine ever since. I just hope it doesn't happen again.
But just going to the dealership for an oil change they tried to get me to get $2000 worth of repair stuff!!! They said my brakes, rotors, fluids, belts, and water pump needed to be replaced. :wtf: psshhh if so, I'm going somewhere else.
I have a whole bunch of codes on my truck...
P0302 cylinder 2 misfire
P0300 Random/multiple cylinder misfire
P0133 02 sensor circuit slow response bank 1 sensor
I put in new spark plugs and new spark plug wires and the P0302 code still pops up (and now the P0300 code pops up, which didn't happen before). I also installed a new 02 sensor in the rear and the old 02 code disappeared but now the one above shows up.
Does anyone have any idea how to fix this?
How much do new injectors cost?
Replaced my injector today, and had a couple of observations to add. I've got a 98 4Runner with the 5VZ-FE engine and TRD Supercharger. The Supercharger complicates things a bit, but I marked all the hoses and took pictures and it came off and went back on OK. The injectors did not come out with the fuel rail, as the manual states. Rather they stayed in the head and the rail pulled off the top. I tried to follow the manual and re-install them by first pressing them into the fuel rail, then installing the whole assembly onto the head. This did not work, as the injectors did not go in far enough for the connectors to clear the rail. So I installed each one separately in the head, pushing them all the way in, then pushed the rail over the top. I had a hell of a time with the front and rear banjo bolts on the fuel rail because of no clearance due to the timing belt cover in the front, and the plastic cover over the wire harness in the rear. No possibility of getting a torque wrench on those things. Nice to have my car back with no misfires.
Steve
PO133 should go away when you get the misfire problem fixed. Mine did. I would assume your problem would be your number 2 injector but your first step would be to pull the intake and test the injector. Good luck.
I just bought a new injector for $50. How hard is it to change the fuel injector on cylinder #2 and how long does it take?
