Originally Posted by a.b.ham
What should I do if I just want the antenna to stay up all the time, and not go up and back down while I simply change the cd? ;)
I have the same fender flares as you have. It's a pain but I did it when I did my Taco Mod.
Turn wheels to the right, gives you a little more room.
Pull the black plastic fender liner towards you. You have to release 2 round clips(pic) that hold it to the body. Release those 2 clips(pic) and pull out the fender liner. You don't have to pull it all the way out,You can't anyway. Once you have that liner pulled out of the way a little stick you head in there with a flashlight and take a look for the electric plug. Its covered over with a clear plastic cover. Just unplug it. Make sure you have the radio on and antenna up when you do it. You can just zip tie the pigtail up out of the way so it doesn't rattle around in the fender.
If you break or misplace the plastic clips that hold the liner to the body like I did you can get them a parts store that sells autobody supplies or you can go to the dealer to get them.
They look like this picture
