Calling everyone running OME 906 coils
econhonda
I put the 906's in the rear along with OME's new shock (60027). Toytec calls the 60027 the only 4runner option since the ARB application guide doesn't list it as a 4runner-specific shock. However, the 906 isn't listed as a 4runner coil either so that doesn't really hold much water seeing as they sell that coil for a 4runner.
I'm wanting to get some feedback about everyone's ride with the 906's. My front end (881's and 90004 shocks) feels just right, but the rear is definitely firm. When I pull into a driveway with a slight bump it is a significant bump with this setup. TRDparts4u.com and Wheelers Offroad both list the OME 60028 shocks as a "softer" shock for the rear 4runner. Anyone running these things? Do other people with 906's think they're very firm? Is anyone running other shocks in the rear? I'm trying to determine if the 906, itself, is the problem, or if it is the shock.
Thanks for your help.
I dont have the 906's, but the 890's. And yes, they are pretty stiff. I imagine the 906's are designed to carry a load just like all OME stuff just with less lift and therefore will will ride stiff as well.
In my opinion, its the springs that give the stiffer ride, not the shocks. I doubt it would make much difference between the sport and comfort shocks and if you replaced you would most likely be throwing money away.
Give it some time to break in and it may help. Throw some gear in the back of your truck too, that may help them break in faster with the added weight.
I wouldnt say its really a "problem", just the nature of the beast.
I agree with you, I recently installed 906 coils with 60027 shocks from toytec, I remember thinking it was strange they did not offer the 60028. If you look in arb catalog the 60028 is recommended with the 906, not the 60027. I email toytec for an exchange or refund, we will see what happens. I was reading a thread form the expendtionwest forum that someone posted similar to this. He said he put cheap $35 gabriel shocks in and took out the ome 60027 and his ride improved dramatically. I think toytec should exchange all people who were sold the 60027. Check out toytecs website,they now give you the option and explain which shock you should buy.
Up until recently, ARB NEVER recommended or listed the 60028 in their application guide for the 3rd gen. They just updated the guide on the 5th of this month to include the 60028 and the only reason why they did that is because we told them about the complaints that we had been receiving about the 60027's. Our ARB rep said that if we get any complaints about the 60027's being to stiff, to call ARB direct. If you have any other questions, feel free to call me
303.255.4959
Thanks
Dylan
303.255.4959
Thanks
Dylan
Are you saying that ARB will replace the 60027 that we bought for the 60028? If so I definately want to do this. My 4runner feels ok on the big bumps but bounces up and down like crazy on normal roads.
I spoke with an Arb tech, they told me that the 60027 shock has never been recommended with the 906 coil. They are sending me the 60028 shocks for free!
I'd say the firm feeling you have has more to do with the shocks than the spring. I'm running the 890s with Rancho RS5000 and the ride feels a lot like stock.
X2
I'm running 891s and Bilsteins. Great ride.
which bilsteins you got?
the 5100s?
Front, Bilstein F4-BE5-2450-HO. Rear, Bilstein F4-BE5-2451-HO. (Yellow Body and Blue Boot) They are a little short for my lift. I will be going to the 5150 when I go to 861s or GY4220s.
I've got the 906's and the 60027's. it's been a really stiff ride since I lifted it. I always figured that was how it was meant to be :bigok:
Would be nice to be just a bit softer.
That is not true.
Here is ARB's application guide for the 3rd gen which was released at SEMA(November). The 60027 shocks are directly below the 906 coil and there is no mention that one cannot be used with the other.
That is not true.
Dont kill the messenger, I am just relaying what the ARB tech told me.
I just spoke with ARB, and they are going to send me a pair of 60028's. Thanks Aschweg! As for the 906/60027 combo, Dylan is right. When I talked to ARB, the tech told me it was an ARB error, not Toytec. While it would have been much easier if Toytec would have replaced the shocks, I understand why they didn't. It wasn't a distribution issue. It was a product issue, and ARB is stepping up to the plate to make things right. When all is said and done, I feel that both Toytec and ARB provided outstanding customer service. I would do business with both again.
A word of warning to those purchasing 906 coils: DO NOT MATCH THEM UP WITH THE 60027's.
I agree with Econhonda, ARB is doing the right thing, I think Toytec is a great company as well. I will continue to do business with the both of them. I wonder if we can get a an update in the lift sticky?
I have the 906 coils but the softer (I think) OME shock. The coils are very stiff unless you have lots of weight back there. They have a very high spring rate, but are a shorter spring. Less travel, more weight capacity. They will still flex, however, if the situation permits...
BigBend438.jpg~original
I suspect that your truck is not heavy enough to get good performance out of the springs. Send your truck to fat school, then come back and see how they work! :driving:
Actually, I thought the same thing at first, but then I removed the bottom mounts of my OME shocks in my driveway, and found that the coils are quite capable of traveling up and down with my jumping on the bumper. With the shocks fully installed, it doesn't move much at all. Therefore, I determined that the cause for the extreme firmness was shock, not coil. I do agree that the coil is stiffer than the OEM coils, but they aren't stiff enough to bounce the rear end of a 4runner across a paved road. Those with 906's, don't be fooled. It's shock, not coil.
Thanks to both of you for bringing it up. I do apologize for any confusion that came from this and I am glad that it has been resolved. If there is anything else I can do, don't hesitate to call me.
Thanks
Dylan
I thought bumping this up would be better than starting a new thread...
econhonda, did you replace your shocks? Can you comment on how the ride is with the 60028 compared to the way it rode stock?
Thanks
