HID kit help (DDM)
hey guys so i got the HID's installed it wasn't too bad I had a buddy help me out with some of the brain work. As for the the weather rubber grommet things, no cutting is necessary. just boil them or run them under hot water and then they will allow it to stretch right over the shield and bulb.
(my buddy came up with that)
I went skiing tonight so i didn't really get any good pictures of the light output but holy crap they are awesome! the 4500k is more of a grayish white it seems. I could see everything and nobody flashed me on the way home from the mountain. The high-beams dont seem to be a difference in well lit neighborhoods but on the open road i could tell a difference.
As for the installation it took me about the same as yall and as for the hangups on short wires and stuff i didn't really see that?? Ill take some pictures tomorrow of where i installed everything. I got it to be pretty stealth, i found some areas to hide the wires and the ballast. As for the ballast I just used 3m sticky tape. i could figure out how to zip tie them on there
I may aim the lights a little lower im still not sure on this one. Is it easy?
here are the pictures ill take better ones later as for now im just being lazy rough day on the mountain right?
had to get matching corner bulbs you can tell the difference between the stock bulb and the LED
005.jpg~original
newlights001-1.jpg~original
maybe if you squint your eyes this will come out more clear haha! sorry bout the blurriness shouldn't have been taking pics while driving...
newlights004.jpg~original
Those look good man.
It's crazy how many of these things sell.
I bought my last kit about a month ago and since then they have sold 11,500 more.
thanks clemson, yeah thats crazy how many they pop out of there, hopefully their making bank! Good to hear yours shipped they are obviously working pretty dang hard over there
Ill post some nicer pics tomorrow or if i can get off my ass and grab my tripod ill shoot some tonight...
So what's this talk of glare? I've read a few threads where members are concerned about the amount of this. Could you enlighten me?
Let me try.
Glare is basically light that ventures where it's not supposed to. On most stock vehicles you will see a pretty nice line where the light starts and stops. The problem with HIDs in a reflector housing that is not retrofitted is that it doesn't control the light very well.
The shield from DDM attempts to stop light from going to the bottom of the housing. If light gets down there then it will be reflected up and could potentially blind someone.
Some people complain and say that nobody should put HIDs in a reflector housing, but if aimed properly they can be fine. You definitely want to check your cut off after installing HIDs.
Here is a picture of the cutoff I'm talking about:
perfectcutoff.jpg~original
hey Clemson haha no its not crooked its just cause i took the pic from the driver seat. in the passenger seat it looks the same but more space on the other side. It threw me off when i first got it too. if you sit in the middle its pretty normal.
I'm gonna ditch the brush guard one of these days im over it... i just gotta find some other options to mount the lights. plus i wanna lift soon but thats way down to who knows when haha.
here is the link to what i got as for the LED's in the corner bulbs. its the big one at natural white (5000k)
2 V-LEDS 5K WHITE 194 13 LED LIGHT BULBS 158 168 2825
how do you re-aim your lights? i think im gonna wait for yall to get your lights and see what you guys do, i dont really want to aim them all the way down, it looks terrible. gosh i wish i had those projectors that beam on your pic looks awesome!
I went out and took some quality pics, and a little of the install i'll post them in a sec.
Here is a link on how to re-aim them:
http://www.toyota-4runner.org/3rd-gen-t4rs/39701-how-adjust-headlights.html
The bolt on the bottom adjusts the height and the screw on top adjusts them from side to side.
Park on a flat surface and aim them at a wall about 20-25 feet away. You should be able to see the glare then.
ok so here is where i installed everything for those of you getting you kit soon. i also have a concern in one of the areas i chose but to start...
this is where i ran the wire from the pass side its fits right under that lip, there are even a couple holes to zip tie it.
newlights008.jpg~original
driver side ballast
newlights009.jpg~original
Pass side
newlights010.jpg~original
here is my concern. i think this thing is the hi beam remote im not sure really do you guys think this spot may be too hot for it to be stored here?
newlights015-1.jpg~original
here are some shots of the lights
stock bulbs. the camera makes it look whiter for some reason??? i do have the LED's in the corners
012.jpg~original
the HID's
newlights016.jpg~original
high beam
newlights017.jpg~original
and lastly inside the truck
newlights020.jpg~original
