TruTrac, in front IFS
I went thru door deep water with the elocker locked and it didn't kill it...messed up some other stuff, but the elocker still works. Is there something about the retorfit maybe that made yours go out LINY?
You could source out a pair of e-lockers:nerd:
but then they'd stop working when you go through deep water like mine did :(
Stick with the ARBs lol :hatsoff:
I've hit up bottom of the door deep muddy water, clearly the motor on the 3rd member housing is submerged....went back and forth 3 times and still going!! Sorry to hear about yours LINY.
3-7.jpg~original
True.. can't beat dual ARB's, though!
Here we go!
Bruce from Randy's Ring and Pinion(866-631-0196) has cleared it up. The 911A342 is the part number for trucks that have a V6 and therefore came equipped with the 1.3" axle shafts. 911A445 is for 4 cylinder trucks because they came with 1.1" axle shafts. You can put a 342 in a 4 cylinder, but then you have to buy a bearing kit due to the shaft sizes being different. Bruce(extension 5117) says most shops will carry only the 342 and just do the bearings so that they only have to carry one part number.
Now, with all that said, the 342 part number has been replaced with the 644 part number but since that change it fairly new, a lot of places still go by the old part number. Summit Racing is already only using the new part number...
Man, I hope this info helps somebody. It sure did take a while to compile it.
P.S. Brian, looks like you were right about the part number and now we know why!:trophy:
P.S.S. Randy's also has the best prices I've found...and they weren't in google. Thanks again Brian!
Not possible! if they arent in google they cant exist! :smashputer:
Glad to help! All these part #s and superceded part #s are pretty confusing. I'm glad Randy's was able to sort it out for you, they're a good shop.
I found out today that Randy's owns Yukon! They had better know what they're talking about! :lol:
Thanks for all the help with the research guys! I'll let you know how it works out....should have it all in by next week!
Was reading this thread and had a question. If you have front/read Trutrac LSD is the center diff lock and the ability to drive in AWD mode still available (01 4R auto). Anything you need to do differently in terms of using the 4WD system in general (center lock, 4H and 4L)?
Thanks
Thanks
A TrueTrac up front will have no affect on how you use the multi-mode 4WD system. Use it as you would now, you'll just have more traction. In any mode other than 2WD, the steering will feel a little tighter, but that's ok, it's just the LSD getting more traction.
:iagree:
Thanks
Yeah the rear you won't feel, but the front one you will feel in the steering wheel. It feels like you're on 10psi in the front tires. It takes a little getting used to, you can't let the steering wheel slide through your hands coming out of a turn because it immediately wants to jerk straight. You're gonna need to actively control it a little more, but it's totally worth it.
Thanks guys for the responses. I may be picking up a 4R that has them already installed and just wanted to make sure what I was getting into and really wanted to make sure the center lock was still usuable.
Not to drag up an old thread, but I have a 1999 4cyl Tacoma with the 7.5 HP front diff. It also has ADD. I'm confused on what Truetrac I can use in this diff.
You can use either, but the 644 will require a bearing kit for the smaller axles your truck has. The 445 should be a direct fit.
I'm gonna do some more research on this. Also, for the people who are using the Truetrac, are you guys using it in the ADD diff?
911A644 / 911A342 Rumors
I’d like to revive an old thread.
Anybody running the Eaton Detroit True Trac part numbers 911A342 or 911A644 have any recent problems with the CV axles pulling out? I have read about the rumors on other threads. I'd like to see if anybody has any recent (2020) first hand experience with them.
I am trying to put this into a front diff that I pulled from a 2000 limited 4runner. I recently pulled an e-locker with a 4.3 ratio and the matching front diff. I was thinking about putting an LSD into the front before swapping it out.
Thanks!
Thanks!
Front TrueTrac Install - CV Axle Fitment Tech
