New tires. Adjust speedometer???
Supertrooper4
Alright so im going from a 265/70/16 to a 265/75/16 BFG All Terrains today. Would i have to adjust the speedometer or any other gages??
The diameter of your tire will increase, so the final gear ratio is off a bit. Not by much though...maybe 2%. So yes, technically the grease monkey is right, but it won't be off so much that you'll really notice it.
The difference may actually correct an error you already had. Have you tested it before and after? Besides, I'd trust the folks on this forum before a tire monkey at Discount tire who may be only trying to up sell you.
really? ok thanks guys, and wait can they reset it or do i have to learn how to do it? haha and how much will my mpg go down???
Fuel efficiency drop will be negligible. Unless you're going to a MUCH heavier tire.
You'd need some conversion hardware to tell the ECU you're going faster than it thinks. For motorcycles, there is something called a "yellow box" (and there are others) that does the conversion on the fly. Not sure this works for cable-operated speedos...but I know it works with Hall effect pickup sensors.
Basically, don't worry about it.
just find one of those fixed speed check stations in a school zone and keep a steady speed and check the reading against the speedo, lol
they are usually pretty accurate to +-1mph or so, haha,
I went from 265/70 to 265/75 a few months ago. The difference is about 2-3% - not enough to worry about it.
If a cop pulls you over for 90, you probably can't argue that your speedometer said 88.
My speedo reading actually is more accurate now with 265/75 than 265/70. My GPS and the speedo agree now, whereas before 70 mph on the speedo was 68 mph according to GPS
