11-10-2011, 05:43 PM
#121
Real Name: Robert
Real Name: Robert
$700 for Tundras/5100's from Sonoran? You have to be kidding me. I will have $250 into mine once I get my 5100's on.
quick, you should just send those sliders my way before you sell your 4runner...
My 4runner Build Thread 2000 Limited 4runner SOLD
My Tundra Build Thread 2006 Double Cab Tundra SOLD
My Humpty Dumpty 4runner Build Thread 1999 Highlander 4runner
11-10-2011, 06:27 PM
#122
SCRunner, how did you manage to spend that little of money? I need a deal like that...
12-25-2011, 10:02 PM
#123
Final post: The rig is sold to t4r.org user DirtDawg. I'm sure he will take great care of the truck, and I wish him the best with it.
I plan to buy another 4runner in a year or two. Until then, I will still be around. Probably just about as much as before. lol
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
12-25-2011, 10:32 PM
#124
Sad to see it go, but happy to see it didn't go far.
Cue "Bittersweet Symphony" please.
02-15-2012, 01:02 AM
#125
Ok, I'm going to just continue this build thread with my new truck. I'm not doing very much to the new one for a while, so continuing my original thread makes ok sense. Plus then it's easy for people to see which rigs I've had.
I just purchased a 2001 SR5, all stock....but with a 4th gen TRD Supercharger. No fuel mods, no nothing. Just the S/C bolted on. The truck is really nice and clean, not perfect, but nice. I'm in the process of doing all the important maintenance items, then hopefully a few fun things too. This is my only vehicle right now, so it's a daily driver extraordinaire. I only have a couple pics right now, sorry.
2001, 186k miles, 4x4, Thundercloud Metallic
02-15-2012, 09:40 AM
#126
Very Nice and clean man! I like it!
1998 4Runner SR5, ISR and Deckplate Mods, Painted Intake Manifold, TRD Tundra Struts, Diff Drop, LC 8 Wraps w/ Skyjacker shocks, Panhard Drop Bracket, Rear Tire Carrier, Maxxis Bighorns, Procomp Wheels, Custom Front Valance, Sport Edition Skidplate, Upgraded Exterior lighting
02-16-2012, 07:16 PM
#128
One of the biggest upgrades I've done to the truck so far!! LED's!!!! WHoo hooo!!!
Seriously though. This is hot stuff. The pictures make them look a little orange, but they are blood red in real life. I like it a lot. I'd done white in the past, and I don't know if I like this better or not. Probably like it equally. I need to change my clock color, and then take a picture with the clock changed, and with my SGII mounted with the red backlight. It all looks pretty good.
The PRND21 indicator lights, the key ring, and the turn signals I did orange. I knew I wanted the turn signals orange instead of red, so I just kind of followed that accessory light theme through. I also used a white LED in the center of the HVAC, so the color temp wheel still looks accurate.
02-16-2012, 07:22 PM
#129
Real Name: Zach
Real Name: Zach
nice! and no hotspots? did you use foil or something?
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
02-17-2012, 03:52 PM
#130
No, I was primed and ready to use wax paper....but it wasn't even necessary with these bulbs. There are a couple barely noticeable hotspots, but nothing that was worth taking the gauge overlay's off and taping wax paper in there.
02-17-2012, 07:51 PM
#131
02-24-2012, 07:29 PM
#132
I installed a JL Audio 10" sub last night, and it's pretty sweet. I've never had a sub in any of my vehicles before. Actually, I've taken them out when I buy one that has them. But in my defense, I was always taking out big 2 12" boxes....and I just installed a single 10".
Anyway, the truck already had a little Alpine MRP-F250 amp running all the components. So I just switched some wiring around, bridged channels 3 and 4 to the sub and it was done. I got the amp dialed in today, and now I look forward to listening to my tunes in the truck because it sounds damn good! Plus by running my components in parallel (just using channels 1 and 2), I dropped the resistance to 2ohms, so I get a little more power from the little Alpine. Seems to be working very well so far.
And I received my Yakima wind deflector. Works perfect, no more howling. And I'm still getting 19 mpg, including a lot of in town driving. Easy does it on the throttle.
02-24-2012, 08:55 PM
#133
Originally Posted by quicksilvr
Here are some real pictures of the truck as of today. It badly needs 265/75's and my '99 springs. But I don't know how long that will take. It works great right now, just doesn't look great. I have to keep my self satisfied with the "working great" for a while.
I think it looks great.
RE the sub, nice addition. I've always thought that 4Runners lend themselves to great bass output, even from a simple setup, because they have similar acoustics to a hatchback vehicle.
So, any word on changing out/inspecting the oil in the nose cone? Did you take the belt off and check the bearings?
02-25-2012, 04:12 AM
#134
Real Name: Ervin
Real Name: Ervin
A sound system is something I've yet to add to my truck, and I'll probably
do it the way you did with a single 10"...just enough to give a good thump and doesn't take up space in the cargo area.
Ha..bet you find better excuses now just so you could use your truck whipping around town listening to your tunes, now that you got a good sound system, eh?..
97 4Runner SR5 TRDSC URD Yukon Camburg Toytec Trekmaster 4Crawler SonoranSteel Level8 Nitto SavageOff-Road ARB Smittybilt MasterPull Powertank SpiderTrax B&M Jaos Gobi Flowmaster Cobra Firestik Alpine CompuStar Hella PIAA RigidIndustries WeatherTech
my build http://www.toyota-4runner.org/3rd-ge...formation.html July 2012 T4RoTM / 2012 T4RoTY
02-25-2012, 04:59 PM
#135
You're right, it looks good. It's just low....I wish it was taller. The 4Runner is awesome for sound systems, my sister's rig sounds even better than mine because she has a better amp and a better sub.
I think I'm good on the nose cone honestly. I took the belt off and spun it around....it spins quietly and pretty freely. I mean, it won't just free spin because of the drag, but it's very smooth. And as far as lash goes, I could BARELY feel a little gap when rocking the pulley back and forth. It was so tiny the pulley didn't even visibly move. I haven't sucked that oil out though. I'm going to let it ride for another week or so, since everything seems good at this point.
A single 10" in a sealed box with a good amp powering the components too....it's a golden setup for a 4Runner. You don't lose the space, like you said, and it sounds awesome. Oh yes, I find excuses to drive the truck all the time.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Build Thread
josh.bunch |
3rd gen T4Rs |
105 |
11-19-2023 12:48 PM |
G.I.G.'s Build Thread
G.I.G. |
Gallery |
33 |
12-12-2015 09:48 PM |
My 03' Build Thread
4Runner8 |
4th Gen T4Rs |
135 |
03-05-2011 12:30 AM |
My build thread
Kirby |
Engines / Suspension / Wheels / Tires / Audio / Accessories |
22 |
02-08-2007 11:02 PM |
