Old 07-21-2011, 05:14 PM #1
ameining's Avatar
ameining ameining is offline
ameining is an unknown quantity at this point
ameining's Avatar
Dash Clock not working 2000 T4R
So I took apart my dash to install a CB, and after reassembling everything works great but the clock in the center above the radio is not working....any ideas????
Thanks
2000 SR5 Sport 4x4 5 Speed - Sonoran Steel Lift Kit System 1.2 - Front: 3.5": TRD coils & Bilstein 5125 shocks -1" diff drop - Silver skid plate - Rear: 4.5": FJ80 coils & 5125 shocks. - Pan/track bar by Sonoran - K&N CAI - ProComp X-treme AT 285/75/16 - Shrockworks Front Bumper - CBI Rear Bumper w/swing away - Shrockworks Rock Sliders - Flowmaster 40 & 2.5" catback - Alpine Type S - All Pro 1.5" spacers - Yakima Loadwarrior & two viper bike attachments - Tinted front windows to match - Sylvania HID fronts - Custom 'hulk' shift knobs - TRD shift knob - Powder coated 5 Star wheels - Energy Suspension Poly Steering Rack Bushings - Black Tacoma Whip - Uniden PRO520XL w/4' Firefly and PA
ameining is offline   Reply With QuoteReply With Quote
Old 07-21-2011, 05:18 PM #2
4-Ripcord's Avatar
4-Ripcord 4-Ripcord is offline
Real Name: Jim
4-Ripcord will become famous soon enough 4-Ripcord will become famous soon enough
4-Ripcord's Avatar
Real Name: Jim
Did you plug it in all the way? lol
Check fuses, if not those then find a clock from a junkyard 4runner.
'13 Tacoma TRD-OR: The Spruce Goose. BUILD
'02 Sport Ed.- V2.0: The better build. Totaled BUILD 2.0
'02 Sport Ed.- V1.0: The college build Sold BUILD
4-Ripcord is offline   Reply With QuoteReply With Quote
Old 07-21-2011, 05:23 PM #3
ameining's Avatar
ameining's Avatar
I am pretty sure I plugged it in all the way, and yes I did check the fuses. Maybe I need to check again, any idea which one would be for the clock? The black wiring harness on the top seems as though it would also control the hazards, which work still...not sure.
Old 07-21-2011, 06:05 PM #4
Elton H's Avatar
Elton H Elton H is offline
Elton H is on a distinguished road
Elton H's Avatar
plugged it into the fake socket ?
98 4runner sr5 3.4L 5spd 4x4 e-locker sold 10/2/11
07 tundra 5.7L 4x4 limited dc was my moms r.i.p 3/19/11
Oregon Toyota Owners Club
Elton H is offline   Reply With QuoteReply With Quote
Old 07-21-2011, 08:24 PM #5
mscj21 mscj21 is offline
mscj21 is on a distinguished road
I just had the same problem after doing the taco whip. Everything else works fine except for the clock, im going to double check all the plugs tomorrow
mscj21 is offline   Reply With QuoteReply With Quote
Old 07-21-2011, 11:01 PM #6
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
The clocks are pretty fragile...well the part that breaks is. Sometimes taking it out, and yanking around on it is enough to make the little springs fall apart. Search "clock repair" and you'll see what needs done. (this may or may not fix your problem, but then you at least know you have a working clock, and it's not the clock that's bad)
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 07-22-2011, 12:03 AM #7
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
the 99 and 00 clocks are known for going out, its not worth getting them "fixed" just look for one from a junk yard or check ebay.
04rnr is offline   Reply With QuoteReply With Quote
Old 07-22-2011, 12:18 AM #8
SKIDMRK's Avatar
SKIDMRK SKIDMRK is offline
SKIDMRK is on a distinguished road
SKIDMRK's Avatar
this. look for the other socket that the plug fits. your clock should then work.
epitome - Like McCormicks, we're seasoned
Build Thread
SKIDMRK is offline   Reply With QuoteReply With Quote
Old 07-22-2011, 10:17 AM #9
quicksilvr's Avatar
quicksilvr's Avatar
Why? Once it's fixed, it's fixed. If you get a junkyard one, it could go out the next day. They are a poor design, but easily remedied by eliminating the flimsy spring contacts with soldered pins.
Like SKIDMRK and others have said....it probably is the fake socket throwing a wrench in your works.
Old 07-22-2011, 10:39 AM #10
ameining's Avatar
ameining's Avatar
this seems to make some sense, however I am a bit confused on what 'fake socket' means. Anybody have photos to describe what they are referring to? Are there two sockets behind there that fit the wiring harness?
Old 07-22-2011, 10:44 AM #11
Just double checked it and I had it plugged in the wrong one. thanks for the help.
Old 07-22-2011, 10:50 AM #12
ameining's Avatar
ameining's Avatar
MSC, can you put of a photo showing the two plugs??
Old 07-22-2011, 01:15 PM #13
I would but my camera is broke but for me i just had to plug the small black plug to the left of the big black plug that i believe controls the hazards, hope this helps
Old 07-22-2011, 02:10 PM #14
ameining's Avatar
ameining's Avatar
So am I understanding in that there are two seperate male plugs, one large (for the hazards) and one small (for the clock), of which I may just not have plugged in the one for the clock???
...because the posts earlier were leading me to believe that there are two receiving plugs and one is a 'fake'
Old 07-22-2011, 02:21 PM #15
rjaudi rjaudi is offline
rjaudi is on a distinguished road
My clock failed and I went and bought a junk yard unit. Well that was coming off and on and died, I sent that clock to a shop on eBay and for 25 bucks the clock works flawlessly.
1997 4runner Limited 4wd- Purchased new by family 12/96
Factory 4.30 e-locker conversion, 265/75 BFG AT, FX-R Hid Retrofit, Kenwood Nav, 231mm Tundra brakes, Grey FJZ80 Wheels, Deckplate mod, ARB Bumper, Hella 4000 compacts, Sonoran Steel 7.2a, Scangauge 2, Extended Diff Breather, Custom Sway Bar Endlinks, Black No Rust Rear Bumper
rjaudi is offline   Reply With QuoteReply With Quote
3rd Gen Dash Clock Fix CO_FlyFisher 3rd gen T4Rs 117 09-24-2021 10:56 PM
Dashboard clock not working trivien110 3rd gen T4Rs 16 11-08-2015 01:05 PM
Clock isnt working in my 97 benbec01 3rd gen T4Rs 6 06-30-2011 02:56 AM
Clock and CD player quit working! Tydog260 3rd gen T4Rs 4 12-11-2009 01:40 PM
Clock not working after install philo Engines / Suspension / Wheels / Tires / Audio / Accessories 2 05-25-2007 02:08 AM
