Radio, clock, cig lighter fuse?
MAD 69
Sorry if there is a thread already on this, I'm on my iPhone so I'm having trouble searching.... My iPhone charger fell apart in the cig lighter and tge metal bit blew the fuse. I have no cig lighter, clock or radio now, can someone tell me where and which fuse I need to replace? Is it under the hood or in the driver side compartment? Thanks for the help...
Edit: is there a fuse at the end of the cig lighter adapter?
if the fuse is replaced (the one inside the drivers side panel) and it still doesn’t come on, what does that mean??
What's not coming on? The clock? Radio? Cig ligter? I know the clocks burn out on these rigs, kind of a common issue I've heard.
The clock doesn't burn out, just the power connections between the dash wiring and the clock internals gets corrosion. Its and easy fix if you know what you are doing.
oh, gotcha! I haven't run into that issue yet, but now I know how to tackle it when/if it arises! Thanks!
