Was under the truck with the grease gun and decided to see if the running board bolts were rusted up—they weren't. Two bolts in I remembered my air gun, made quick work of it. All they do is get my pant legs dirty. ‪
*free to good home, must pick up in 05089.
Now I can see a lot of stuff under there though, which should inspire me to get the wire brush and some POR15 out this spring.
Looks much better without them, but I can tell you from experience you pant legs will only get dirtier without then.
lights!
Installed my "amazon" LED interior light kit and backup lights! Not bad for $20...thanks t4r.org!!20141230_134859.jpg
Looked at it when I pulled Ole reliable out of the garage.
Technically it's the wife's..... I haven't fully been able to love it since it ganks all power etc when a wheel spins. I know there's ways around that..but.............................................................
Ole reliable is the 00 Regal with 253K. I added a few things when I picked it up at 160K
I drove through a wet field on bald tires. I felt like I was hydroplaning the entire way through it. New tires are coming in January. I will be putting on 265/70/17 most likely unless I can go a little wider
Happy New Years Guys!!!!! Many Mods to be posted here this year, can't wait for it all. Here's a little one I've been meaning to do. Finally have the knife ready at a moments notice.
Met up with [MENTION=100305]TiN[/MENTION] to buy his old spec halo headlights for a good deal! At least try them out while I mess with my stockers. Will probably end up sitting for awhile but who knows! Thanks for meeting me TiN, let's get some locals together and grab some grub!
I found an open parking space and tested the articulation of the stock suspension! I would have gone higher, but the snow pile was collapsing under the weight. And I think that's about as much as it can move (no lift).
(it's hard to tell from the picture, but the front wheel is a foot or two up the snow pile)
I bought my T4R three weeks ago. Had 105k, one-owner/dealer-maintained with full service history listed on Toyota owners site. Still, I have OCD with maintenance so I had some fun:
Changed oil to M1 5w30 EP w/ new filter
Changed plugs (NGK oem spec)
Installed aFe Pro Dry S air filter
Removed HCF
Changed cabin filter
Disabled TPMS
Drained & filled trans w/ WS x3
Drained & filled xfer and both diffs w/ M1 75w90 synthetic
Lubed all 6 zerks w/ M1 synthetic grease
Drained (both sides of block and radiator) & filled SLLC
Drained & filled PSF w/ M1 Synthetic ATF x3
Just gotta do the brakes and I'm all caught up!
