07-10-2018, 12:33 PM
#2956
Originally Posted by 08SprtEdtn4wd
Greeting all,
I'm the proud owner of an 08 SE with a V8. In the next couple months I'm planning on installing one of them nifty C4 Low-Pro bumpers and a 10k winch. I'm currently running Blistein 5100's on all 4 corners, stock springs in the rear with a 1.25" Traxda spacer and OME 2885 springs up front (2"). I know that adding the bumper and winch is going to add significant weight to the front end and I'm wondering if any of you fine knowledgeable peeps could make some suggestions as to what, if any, changes I should make to my front end to account for the extra weight. Should I be upgrading the springs? Shocks? Leave as is?
I'm trying to prevent the front end from dipping and/or taking a dive upon braking. Any and all suggestions and points of views will be greatly appreciated.
Thanks all!
Originally Posted by SHagood
If I'm not mistaken, the C4 Fab bumper only weighs about 70lbs or so. Thinking of getting the same thing on mine. Post pics once you get installed.
I've got the C4 Lo-Pro. It weighs around 75lbs, plus my winch (roughly 85lbs), you're looking at about 160lbs to add. Conveniently for you, I also run 5100s with an 885 spring in the front. The front definitely dipped down, but not a ton. Maybe about 3/4"?
I'm planning to put a 3/8" spacer on the left side, 1/4" on the right. Will fix the driver's lean, and should help regain a half inch in the front.
2003 4Runner Limited 4x4 V8, Volant CAI w/ LC100 snorkel, modified C4Fab hybrid bumper with wings, Superwinch Tiger 9500, RSG Angled Sliders, 5100s/885/RCC2.0, TRD Wheels, Duratrac 285s, 1.25" Spacers, RIGd Ultraswing
07-10-2018, 03:18 PM
#2957
Originally Posted by J-Roc
Yes for sure! I plan on doing the front springs at the same time as the shocks.
Was just wondering if I could leave there rear airbags while using 5100’s all the way around.
If you plan on keeping RAS you should order bilsteins 4600 for the rear. If you read ARK Swamp rider's post on the conversion he mentions about this. I will send you a link for this once I find it.
07-10-2018, 03:42 PM
#2958
07-10-2018, 10:48 PM
#2959
Real Name: Matt
Real Name: Matt
Originally Posted by theoutbackdream
Anyone running 35s with JBA UCA's?
How close are you to rubbing the body(IE: do you get enough caster out of it) and how much offset did you need to clear the uca from the tire?
Anyone?
07-11-2018, 07:14 AM
#2960
Looks clean, I'd love to get one. Only thing I'm worried about is if I add that, I'll have to replace springs in the front and that'll disconnect my XREAS (if I'm not mistaken). So until the XREAS goes out, I'll run stock. Suggestions?
07-12-2018, 01:10 PM
#2961
Need new UCAs?
I installed the lift in my sig a few years ago and since then, when I get to the downside of a rounded curb or speed island, there is a quick grind. It seem like it happens when the wheels are straight.
1. Is this due to the UCAs rubbing? The lift was stated as being 2.5", but I think I've read where people have gotten ~3" with listed parts. I didn't take any pre-lift measurements. I went to a very reliable alignment shop after lift and was told all the numbers were fine.
2. IF this is the UCAs, Camburg and JBAs seem to be the way to got for this size lift and my very occasional rough dirt roading. What is your choice and why?
Thanks!
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
07-13-2018, 09:38 AM
#2962
That's not correct. The calving for the 4600s and the 5100s are the same in the rear. They just make them silver to match the fronts which are differently valves for the adjustable spring seat. Also the 5100s are perfectly suited for RAS. I've been running this setup for 50k or so
07-13-2018, 02:56 PM
#2963
Real Name: Orlando
Real Name: Orlando
Bumper added weight options.
So, I should anticipate to lose about 3/4" on the front end.... good to know. I'll have to find springs that are a bit stiffer then? to make up for the dip?
Also, you mention a driver lean... is that due to the added weight from the bumper and winch? Should i be anticipating something similar?
Thanks for the info; your rig looks awesome.
ForceStop Cross Drilled/Slotted rotors w/ceramic pads, FlowMaster Katback Dual OTB Exhaust, Terra Grappler G2s 265/70R17's, Spidetrax wheel spacers, blacked out front grill, 32" LED fitted into front bumper, blacked out headlights w/halos, C4 Hood scoop LED lightbar, CBI hood hinge brackets with flood LEDs, WeatherTech Mats all around, Rear view camera w/monitor in rear view mirror, Pure White interior LEDs all around, FN FXPro wheels, Bilstein 5100 on all corners, OME 2" springs in the front and 1" spacer in the back, C4 LowPro Bumber w/integrated 11.5k SuperWinch, OffGrid Engineering Dual Battery System, Kenwood Head, Toyota Homelink Module, rear/backup LEDs integrated into rear bumper, RSG Rock Rails, Smoker's kit.
07-14-2018, 12:46 PM
#2964
Have you checked for contact
Thanks!
between the OE UCA and anything else. If youre hearing a grinding noise there could be evidence on a part..or parts
07-15-2018, 01:37 AM
#2965
I've looked, but I'll have to do a more thorough search. Been under there a couple times and didn't see anything that looked like newly rubbed metal.
07-18-2018, 05:39 AM
#2967
4th Gen Suspension Options/FAQ
Originally Posted by schuler317
The rears shocks look like they might fit, you’d have to check the length and bushing diameters, but the fronts definitely won’t because the bushings are wrong and look like a shock rather than a strut that goes inside a coil. The rear springs might be fun to play with, but looks like the fronts won’t fit.
2019 4Runner TRD Off Road Premium Classic Silver Metalic
Sold: 2005 4Runner Sport Edition 4x4 V8, K&N Drop In Air Filter, HCF Delete, WeatherTech FloorLiner Mats, Integrated Bluetooth, 2006 OEM LED Tail Lights, Yakima LoadWarrior, Cooper Discoverer AT3 265/70/17, Front: SPC UCAs, Bilstein 5100 at 1.75" FJ 4X4 Coils, Poly Sway Bar Bushings and Drop Kit, Rear: Bilstein 5100, FJ Coils, Daystar 1.5" Spacer, Spidertrax 1.25" 2015 Trail Edition wheels. 230,500 miles
07-19-2018, 02:51 AM
#2968
Need some advice!
I have a 2005 SR5 V8 with 102k miles and no XREAS; starting to upgrade my suspension slowly. So far, I have the 5100's and nothing else. I am new at this and trying to read through posts/threads on what to do/get and not to do/get.
I do not want a crazy lift, thinking of doing the 2/1 kit from Burtman's. I like the way user monk96t 4Runner looks, especially with the A/T tires.
Since I'm doing the 5100's, I figured I would update/upgrade my coils. Which ones should I get to go w/ the 5100's and the 2/1 kit? I've seen some many posts about Moogs, OME, Toytec, etc. Just overwhelmed by the choices.
Is having aftermarket coils and a leveling kit the same thing or redundant and I could get buy with buying one or the other? This is what I am confused about.
What setting should the 5100's be at when installed? 0 is what I am thinking.
Thanks
07-19-2018, 11:14 AM
#2969
To achieve a two & one inch lift
Thanks
I went the 6112 route setting them @ 2"s ie: 5th clip on driver side and 3rd clip on passenger to compensate for driver side lean due to driver, gas tank. dobinson 323 coils and soon to be 5160 rear shocks. So basically a trd pro set up. like it alot.
07-19-2018, 01:19 PM
#2970
Real Name: Chris
Real Name: Chris
Thanks
Skip the 2/1 kit. I went with Toytec 521600 in the front set to 0 and OME 2895 springs in the rear and it was nice and level. I had to add a 1/2 inch spacer to the front after the bumper but that was it.
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
