Removing roof rack crossmembers from 06 Sport Edition
woodyc
Has anyone removed the cross members from an 06 Sport Edition? I'm gonna remove mine to add some Yakima surf racks. I understand the rear cover piece has to come off but I can't see how to start the process. Any pics anyone has would be helpful. Thanks.
I no longer have the Sport Edition roof rack on the 4runner but I still have the parts. It's actually very simple but you have to remove the mounts from the roof. There are a couple of washers that keep water from coming inside that you have to be aware of when you reassemble. For tools, you'll need a thin pry tool like a putty knife (I used a paint can opener), a T-40 torx bit and a smaller torx bit (don't remember the size).
You will have to remove both the driver's and passenger side mount.
Start by locating the seam where the top cover meets the bottom cover.
P1030307.jpg~original
Split the seam with the pry tool.
P1030310.jpg~original
It may take a little effort to pry it up. Once you get enough of a gap you can use a large flat blade screwdriver (wrap the blade with tape so you don't damage the plastic cover) to pry it up the rest of the way. I was able to do the job with just the paint can opener.
P1030311.jpg~original
Once the cover is off, you'll see two torx bolts. Remove those. There's also a small torx screw on the side of the mount where it connects with the rail. Remove that screw.
P1030312.jpg~original
Place something under the rail (like a block of wood) to support them when you remove the mount. Once you remove the mounts on both sides, loosen the locking knobs on the cross members and slide them out the ends of the rails.
When reinstalling the mounts these are the washers I was referring to that keep water from getting in the cabin. Theres a paper washer between the top of the bolt and the mount. The there's a pliable, gummy washer between the bottom of the mount and the roof. You'll also notice the bolts have a green sealant on the threads. You can probably use silicone sealer to seal these areas.
P1030318.jpg~original
P1030315.jpg~original
Thanks Dawg Runner!
WOW. Finally some good pics of this process!! Sorry it took me so long to respond. Appreciate the time you spent and the attention to detail
Thanks!
Woodyc
