URD MAF cal
Daron-t4r
UPDATE: INSTALLED: standby for more
OK, I installed the URD MAF calibrator, so this is my semi write up for everyone.
First, I took off the glove compartment completely, and the trim under the glove compartment, which holds the 4WD ECU.
By nadroj6
Next, following the PDF which I can send to people, I labeled the 5 plugs, ABCDE
By nadroj6
Then following the diagram ,again on the instructions, stripped the correct wires, and spliced the PCU to those wires.
By nadroj6 at 2011-12-18 The last one requires cutting the ECU wire to the MAF sensor, but I sucked it up and cut the wire, connecting the two PCU (portable control unit/the calibrator to each end of the cut wire.
By nadroj6
I put caps on some of the connections i made
By nadroj6
Next, once everything was wired in, I used industrial velcro to velcro it inside
I'll report later on the effects of the URD calibrator, so check back in a while and I'll update the Thread.
If anyone in the future needs help with installation, or has questions about the installation, I'm glad to help.
Underdog Racing Development
Thank you!
Ok, I found it, If anyone needs the PDF I can send it to them.
My next question is, does anyone have a picture or video of where they mounted the URD unit... I've got some electrical skills, but I don't know exactly where to put this unit.
EDIT: Also where is the ECU that I need to connect to?
I don't really have an answer to your question but i'm curious about you experience with the unit. Did you notice a power difference after installing it? Did you install it just because of your CAI or are do you have an exhaust too?
Lol, the x-runner forum kinda matches the x-runners... really cool, but i feel like there be too much bling... which is slowing it down.
I don't have an exhaust at the moment, but i do plan on adding one in the future, it also helps with the MAF ratios at this elevations ~9000 feet.
The unit seems great, havn't noticed a considerable sound difference, and havn't driven enough to see a change in the MPGs... but it seems to jump right into second gear, and nothing has blown up yet.
More on the way...
