Spidertrax Ordering Question
zerowkul98
Im looking to take my 08 and do the following:
- Put on 1.25" Spidertrax spacers
- Find some 18" OEM wheels with some new BFG Rugged Trail's
Im on the SpiderTrax website and i cant seem to find any info on HOW MANY spacers come in "a set".
Is it for one wheel? All four?
Hmm...thanks for the info. Im on the Spridertrax website and i cant seem to find any language as to the qualtity-per-order.
Might have to give em a ring.
Thanks
Definitely get the extended lugs and I picked up my loc-tite from Home Depot, Lowe's will have it or any other home improvement type place will.
And yes, they come in pairs when ordering.
Also recommend getting extended thread lugs from all-pro, and a tube of locktites. They supply you with some but not enough.
I'd got the all-pro ET lug nuts and they do not work with spidertrax. Here's a picture of one ET lug in the hole on the left and one on top of the spacer, while the right hole has a spidertrax acorn style nut in the hole as well as on top for comparison. You won't be able to get your wheel on with the ET lug nut since they don't sit low enough.
Wow! Thanks for all the info!
So i take it from all the info that i SHOULD NOT look into extended lugs? Are they an option when buying?
Spidertrax does not offer any type of extended lugs. All Pro makes an extended lug nut for their spacers. Based on the comment above, it doesn't look like the AP extended lug nuts are compatible with the Spidertrax spacers. If you're going Spidertrax, just use lock-tite and call it good.
Snowboarder
Did you get the spider trax on yet? Can you get a photo of them on with the et lugs for reference.
Hey, to be honest I have not even put them on yet. Shame on me, I know. They're still sitting in the box! I'm trying to determine whether I actually need them or not due to my Enkei wheels, which already have an offset. I commented on another thread to see if anyone knew if I would, but didn't get any answers.
What exactly do you want a picture of on the spacers?
