120000 mile service for 2004 4runner?
mitre
can anybody tell me what needs to be done for the 120k maintenance on 2004 4wd V6?
I'm taking it to a local mechanic and want to make sure he uses the right stuff
oil change (what type of oil and any preferred brands)
transmission (what type and brand)
spark plugs, etc
rotate tires,
anything else
the owner's manual was in the glove compartment but i couldn't find the maintenance booklet. this is my first 4runner so i don't have a clue what products should be used on it. I checked the toyota owner's website and they don't have the booklet there. Any suggestions on where i could get one? Should i just call toyota or is there a place on the web?
You bought a 2004 at 120k miles? Did you not read at all before buying? They require a complete engine rebuild at that time due to a shim that was out of spec.
Big $$ pit 2004's are.
I read about the head gasket, transfer case, and the catalytic converter. I did see some engine rebuilds but there were a lot of people who seemed to be doing ok.
I thought all 4th generation 4runners V6 engines were the same, 1GR-FE V6 4.0 Liter engine.
could you pls post a link so i can read about it? thx
Don't listen to clockwork. All evidence points to him misleading others in the past. I reported this post with the following:
"Clockwork is purposely misleading people by doing this. Last year, under an alternate username, he misled someone to the point that they almost lost a deal they had set up at the dealership. "
He's playing aroun with you.
This is from the Toyotas mant. Booklet.
120,000 mile Mini service
Replace engine oil & filter
Rotate tires & inspect tire pressure
Fill fluid to proper levels
16 point inspection
replace engine air filter
Replace engine coolant
Replace 6 non- platinum spark plugs
'03 & newer ( include cabin air filter)
120,000 mile Max service
A/C refresher service
Balance 4 tires
Battery service (clean terminals)
Brake inspection
Fuel induction service
Replace wiper blades
Check alignment
Transmission drain and fill
Clean & adj rear brakes & parking brake
'03 & newer (include cabin air filter & non- platinum spark plugs)
Yea. I agree. Don't worry or fret. Just do the regular maintenance. Cars break.. all cars break, and only god knows when. Don't let him scare you with his doomsday predictions. He literally worships his engine and I suspect, would like to make sweet sweet love to it if it were possible and as such, he is heavily biased.
thanks again. I've read a lot on this forum and kind of figured that clockwork loves the v8. hopefully i haven't started another v6 vs v8 thread
My sister's 2004 T4R V6 had 202K before she traded it in. No problems with the V6. We changed the sparks plugs, struts/shocks, front brakes, and routine maintenance. It was still in great shape with many more miles to go.
Don't worry about having to do a complete engine rebuild. You'll notice Clockwork has been banned.
Ice pretty much summed it up with all the things you should take a look at. As far as routine maintenance goes I would change all fluids out (oil, diffs, transfer case, radiator, power steering, brakes, maybe transmission).
16 point inspection
Just came back from the mechanic shop. Everything you have down plus new water pump and yearly inspection for $705. :)
Called to have the mechanic check all the fluids and to change them if they need it. Hopefully they are all good or can at least last till the next oil change.
16 point inspection
Thanks for copying my post. A******
Sadly, I feel like this same cycle is just going to start over again... He'll inevitably create a new name and get back to his same old s*** in no time...
- Sent via Tapatalk for Android
We know his "modus operandi" though. He should be easy to detect.
Too bad they can't ban by ip address.
Easy to bait as well. Just critique the V8 once in a while.
16 point inspection
Damn, just saw the receipt of the service i just had. Mechanic used NGK platinum spark plugs. Will this be okay for the engine? I don't know a lot about spark plugs and just wondering if i should get them changed out.
N/M - just visited the NGK webpage and they have the NGK laser platinum spark plugs as being compatible with the 4.0 V6 1GR-FE FI.
